2013 accord amp wiring help
Old Mar 1, 2013 | 07:39 AM
Spoolme's Avatar
Default 2013 accord amp wiring help
My question is if I use the high level input when installing can I use the wires that plug into the factory subwoofer? Keep in mind that this signal would be filtered through the factory crossover and amp at this point. Would that matter? If it does, does anyone know what wires I can tap into pre-factory amp?
Old Mar 7, 2013 | 07:49 AM
keep_hope_alive's Avatar
depends on what you want the amp to power.
if you want the amp with high level inputs to power a sub, tapping the factory sub speaker wires is a good idea - but remember two things,
1. you need to disconnect the ANC system microphones.
2. you should remove the factory sub completely.
if you want the amp with high level inputs to power speakers, tap the factory wires that feed the speakers you are replacing (front or rear).
Old May 12, 2013 | 07:56 PM
3ric's Avatar
you dont want to put a aftermarket system its a hassle only cause of the mics in the car there two one in the front and in the rear
Old May 15, 2013 | 07:24 AM
bypassing the mics is fairly straightforward.
trymes
Aug 16, 2013 09:04 AM
drumdoctor
Jan 16, 2012 09:53 AM
khan14@hotmail.com
Dec 5, 2009 02:57 PM
zann121
Jun 8, 2009 11:50 AM
rexzilla25
Dec 11, 2008 09:15 AM
