2014 Accord Sport Audio Install
2 Attachment(s)
first build for me in 10+ years, so i am basially starting with no knowledge.
das auto: http://mobileaudioforum.com/forum/at...1&d=1390532079 planned: KnuKonceptz Kno Knoise ultratouch thermal barrier 2- alpine type s componets 6.5" 2- alpine type s coaxials 6.5" (rear deck) Precision Power PPI 900.5 Image Dynamics ID12D4 Navone Engineering LOC i am looking mostly for sound quality, but still dont want to spend an arm and a leg. starting to roll in https://www.hondaaccordforum.com/for...ine=1393687667 may be able to install sunday as right now its 4 degrees outside https://www.hondaaccordforum.com/for...ine=1393687667 will try to update asap. http://mobileaudioforum.com/forum/at...0&d=1390532040 my first mod. just got the oem tweeter panels from the expensive model accords and filed them down to accept the alpine tweets in their own enclosure. loved how they swiveled in their mount, so i kept it!!!! http://mobileaudioforum.com/forum/at...9&d=1390615058 |
thanks for sharing.
can you describe how you mounted the front speakers and if you measured the available depth? did you make a mount? did you reuse factory? i recommend weatherstripping foam seals around the front of the speaker so it seals against the front door panel. door panel/grill needs to have an airtight seal to the speaker so you get midbass response and minimal phase cancellation. |
Originally Posted by keep_hope_alive
(Post 341780)
thanks for sharing.
can you describe how you mounted the front speakers and if you measured the available depth? did you make a mount? did you reuse factory? i recommend weatherstripping foam seals around the front of the speaker so it seals against the front door panel. door panel/grill needs to have an airtight seal to the speaker so you get midbass response and minimal phase cancellation. did not measure, just assumed they would fit :o ya i prolly oughta do that, just have a little deadener around the opening atm. im still far from done, it is starting to warm up here so hopefully ill get "done" soon man you caught me off guard changing you avatar :p |
little update.
got power wire ran! well, its not hot, i did the hard part! anyway on to pics. comin into trunk http://imageshack.com/a/img844/1521/gohg.jpg lovin the techflex http://imageshack.com/a/img22/9291/34fv.jpg http://imageshack.com/a/img208/8676/9ibk.jpg drilled thro firewall and used a grommet. it is right above the dead pedal inside, well out of the way. http://imageshack.com/a/img834/9940/g5to.jpg http://imageshack.com/a/img69/2512/va8p.jpg http://imageshack.com/a/img802/8833/o0rc.jpg http://imageshack.com/a/img542/8978/q4sk.jpg |
got more done with help from pops.
LOC is hooked up, save the remote wire. that was my main objective today. also the power wire is now hot! http://imageshack.com/a/img542/1718/ilza.jpg http://imageshack.com/a/img59/1494/kvuj.jpg labeled **** so i dont get confused :D http://imageshack.com/a/img541/9990/cqxn.jpg temco hammer crimper, love it. btw, when crimping, have a little of the wire sticking out the ring end as to get a good bite on the wire. learned from trial and error :confused: http://imageshack.com/a/img855/9459/8tkp.jpg Wire's HOT YO! http://imageshack.com/a/img59/3922/rl1d.jpg also factory, ive got a 4awg battery ground so im not gonna mess with it right now. 1/0 is way overkill for my power needs now. |
getting closer to ludicrous speed! http://mobileaudioforum.com/forum/at...3&d=1394673547http://mobileaudioforum.com/forum/at...4&d=1394673564 |
1 Attachment(s)
IT IS DONE!!!...for now https://www.hondaaccordforum.com/for...ine=1394892181 love it, sounds so good. taped up so they dont come loose http://imagizer.imageshack.us/v2/xq90/546/q4bm.jpg http://imagizer.imageshack.us/v2/xq90/541/4ke1.jpg http://imagizer.imageshack.us/v2/xq90/513/dujs.jpg http://imagizer.imageshack.us/v2/xq90/809/nmvt.jpg http://imagizer.imageshack.us/v2/xq90/199/0kto.jpg http://imagizer.imageshack.us/v2/xq90/577/4f6j.jpg http://imagizer.imageshack.us/v2/xq90/850/owpn.jpg |
glad you're happy with your efforts.
looks good. you can spend some more time with wire routing to try to get most of it secured every 6-8" or so. you can use zip tie mounts. make sure you get some L-brackets in there to rigidly secure the box in place. while it may seem secure with friction, you want it difficult to steal and secured such that fast turns or an accident doesn't cause the box to move and stress the connections at the amp. |
