2014 rear sub size from the factory
Old Apr 11, 2014 | 09:35 AM
Whozplaying's Avatar
Default 2014 rear sub size from the factory
Will simply swapping out the factory sub for a higher quality one solve the weak bass issue on my 2014? What size is it?
Old Apr 11, 2014 | 02:19 PM
berrnard's Avatar
technically no. the issue is the "360"w amp. it is way underpowered.
u could possibly notice a slight improvement but imo, youre just wasting money.
if it is the same as my civics ive had(which it probably is) 8"
Old Apr 11, 2014 | 03:50 PM
But swapped out and connected to its own power amp would probably work, correct?
Old Apr 11, 2014 | 08:25 PM
berrnard's Avatar
yep. if kept in the stock location, may have to fix rattling issues.
i would suggest sound deadening on the metal deck and some ccf or insulation sandwiched between the metal deck and the plastic deck when it gets re installed
Smilesick
Feb 8, 2014 08:05 AM
Spoolme
Mar 7, 2013 07:25 AM
s10xtremist
May 5, 2009 05:56 AM
Jay1024
Oct 2, 2007 12:08 PM
karb0nk0py
Sep 14, 2007 11:50 PM
