2015 Speaker replacement (?)
Old Aug 9, 2015 | 02:02 AM
Prospector's Avatar
Default 2015 Speaker replacement (?)
Wanting to replace/upgrade the speakers in my 2015 Accord Sport.
The front should be an easy swap, however from the research I've done thus far, it appears that the only way to replace the rear deck speakers is to remove the entire (upper & lower) rear seat... Right or wrong? Is there any other way possible to remove & replace the rear deck speakers?
Old Aug 9, 2015 | 05:54 AM
I moved this to the audio section. Pretty sure the '14 and '15 are the same. You might want to look thru KHA's thread where he is building the audio system in his '14.
https://www.hondaaccordforum.com/for...q-build-58960/
Old Aug 9, 2015 | 02:04 PM
Prospector's Avatar
Thanks, Poorman
That thread was informative as far as the front speakers are concerned, however I'm seeking info on replacing rear deck speakers. From what I've found so far, looks as if there is no way to get around having to pull the rear seats
Old Aug 10, 2015 | 11:14 AM
berrnard's Avatar
you don't need to pull the rear seats, but it is a little easier if you do. and the rear is held in be 2 bolts and a couple push pins.
you do need to remove the side bolsters which are 1 bolt each under the rear seat. you just need to lift up the rear to see it. then it is a matter of pulling out plastic pins but the rear deck is the biggest PITA. it is tough unless you have something with leverage like a pry bar.
having said all that, if you are doing a simple upgrade-don't touch the rears. they do nothing IMO for the overall sound, i even had my rears juiced by amp at one time. i would leave them and tune the radio to move all the sound to the fronts.
Old Aug 10, 2015 | 03:04 PM
Prospector's Avatar
Thank you for responding, Berrnard
I will take your suggestion as a consideration, indeed by replacing only the two front, that would lower the expense of the upgrade. However, unless there are passengers in the back, I do like to set most of the volume to the rear speakers and then blend-in the front
Old Aug 14, 2015 | 12:03 AM
keep_hope_alive's Avatar
just let the stock rears stay as-is. the factory system greatly attenuates them anyway. they sound fine for rear passengers and good front speakers will be clearly audible to rear passengers as well.
Old Aug 14, 2015 | 01:17 PM
Prospector's Avatar
Thanks, will keep this in mind
Old Aug 14, 2015 | 06:00 PM
Frugalhondaguy's Avatar
I found this link that are supposed to be for a Civic, but they look like they may fit on an Accord
Bonnet Hood Gas Strut Shock Damper Kit Fit Honda Civic FN FA FD 06 | eBay
91boz
Feb 8, 2008 07:17 AM
setnogood
Jan 18, 2008 12:17 AM
2kflhr
Apr 2, 2007 07:30 PM
jimsmith
Jul 15, 2006 07:26 PM
03Sleeper
Jun 29, 2006 05:22 PM
