94 OEM stereo-no sound
Old Jun 12, 2010 | 05:42 PM
valerie's Avatar
Default 94 OEM stereo-no sound
So my car was stolen, and they took my Pioneer stereo. Anyways the stock harness was not chopped up when the pioneer was installed so I went and bough a OEM radio and it plugs in perfectly to the stock harness.
I called Honda and got the security code and now it goes on and has the display working, I can set the stations and hear a beep, but I get no other sound out of the radio.
Do you think the old radio is blown or am I missing something?
Old Jun 13, 2010 | 01:35 AM
makumakaku's Avatar
not so sure... but did you check your antenna?
Old Jun 13, 2010 | 09:56 AM
keep_hope_alive's Avatar
did they take your speakers? or disconnect them?
the beep can come from inside the radio.
if it will let you tune stations with a seek function then the antenna is probably ok.
Old Jun 13, 2010 | 01:15 PM
valerie's Avatar
Speakers are there, not sure if they disconnected them. I will check into that, but I thought the beep was from the speaker.
Old Jun 13, 2010 | 08:34 PM
the beep may be, you'll have to put your ear near a speaker and listen.
did the head unit you bought need a separate factory amp?
Old Jun 16, 2010 | 10:49 PM
valerie's Avatar
After pulling the radio out I see a sticker on the that reads " this unit will not operate without the CD changer or special plug ( I think that it said special plug ) inserted. Anyone know what plug they mean?
Old Jun 17, 2010 | 03:18 PM
ah, you got the wrong OEM head unit, unfortunately. to use that head unit you'll need to buy the matching CD changer and wire harness - at which point you'll spend more than just buying a simple aftermarket head unit. it is possible you could just get the plug that completes the audio circuit. You can check hondapartsdeals.com and see if they sell that part separately.
my suggestion is to try and return the OEM radio and buy a standard aftermarket Alpine, Pioneer, Kenwood, etc. for about $100 at any local Best Buy or similar store (not Walmart), or even less if you buy used. Or you can find an OEM radio that doesn't require the CD changer, or find the "special plug".
Old Jun 18, 2010 | 12:35 AM
valerie's Avatar
I found the plug at a local JY, put it in and I heard thump, thump, thump from the speakers, but still no radio tunes.
I just wanted to keep it OEM so I didn't have to cut up the factory harness, but I just might have too.
Old Jun 18, 2010 | 12:40 AM
Arrow Hi Val
Let us know when you get it fixed up and what you did...
Old Jun 18, 2010 | 12:59 AM
you never have to cut up a factory harness. 70-1720 is the Metra harness part number for that vehicle. it allows you to install an aftermarket radio without cutting up the harness. don't cut a harness off.
i think you bought the wrong plug. what is the model number for the radio you have? it should be printed on the radio case.
