94 radio and digital clock wiring problem
Old Nov 15, 2010 | 01:13 AM
jalospride's Avatar
Unhappy 94 radio and digital clock wiring problem
well i just purchased my 94 accord ex vtec and it came with an aftermarket radio.it was hooked up incorrectly because when i removed the key from the ignition, it would still stay on and drain the battery.so, i decided to redo all the wiring correctly and hook it up with correct connections.as i did this.i believe some wires touched and caused a spark(hot wire and maybe some other wire).i have already checked under the hood to see if the fuse blew out and nothing.but now the worst thing is that my radio wont turn on at all?>,< and i also noticed that my digital clock is way dimmer than the usual.what can i do to fix this please help.
Old Nov 15, 2010 | 02:10 AM
PM G22 and see if he can help you on this question.
Old Nov 16, 2010 | 12:25 AM
jalospride's Avatar
?i pm him already but no response...?i need help please people.yes i am new to this as well...
Old Nov 16, 2010 | 12:28 AM
jalospride's Avatar
Question
Old Nov 17, 2010 | 12:29 AM
keep_hope_alive's Avatar
did you test the radio memory and ignition fuses with a DMM to verify they are good? you need to meter a fuse to know for sure - that is why they have small tabs you can touch with a DMM while the fuse is in-place.
simply set the DMM to measure VDC, ground the black lead, and touch the red lead to the fuse tabs (both). if you have voltage on one but not the other, you have a bad fuse.
next, use the DMM behind the radio to test the ignition and constant wires. also, ensure the head unit is firmly grounded to car metal.
Old Nov 17, 2010 | 09:36 PM
jalospride's Avatar
would that make my digital clock dim though?will it fix the dimming?
Old Nov 18, 2010 | 10:07 AM
Why not try fixing it 1st and then see if the Dimming stops with the problem...
Old Nov 19, 2010 | 12:09 AM
jalospride's Avatar
alright.so i got the dimming to stop.now i have a weird problem...wiring.it isnt as said on the posts that i have found.i have a white/yellow wire and a yellow white wire...and obviously the white with red that is switcched...well i dont know which wire of the yellow/white and white/yellow go where...and in the diagram that i saw.there are two of the same wire colors used...so i dont know how to hook two wires to one?it isnt working.am i making sense?if you see the diagram, it says constant is yellow/white as well as car antenna trigger...what do i do???i dont wana blow my 4th fuse.please help
Car Radio Battery Constant 12v+ Wire: Yellow/White
Car Radio Accessory Switched 12v+ Wire: White/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Yellow/White
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4″
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): Red/Green
Right Front Speaker Negative Wire (-): Brown/Black
Car Audio Rear Speakers Size: 6 1/2″
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Blue/Yellow
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): Red/Yellow
Right Rear Speaker Negative Wire (-): Brown/White
Old Nov 19, 2010 | 08:17 AM
you can use a DMM to measure each wire to determine what they do. Just measure voltage on the wires with the car off and on (taking care not to let wires touch metal).
This is what I found for your car, which is different than your list.
http://www.modifiedlife.com/car-ster...-honda-accord/
1994 Honda Accord Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/White
Radio Switched 12V+ Wire: Yellow/Red
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: N/A
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2″
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: 6″ x 9″
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
Old Nov 19, 2010 | 08:20 AM
Separate source
http://www.the12volt.com/installbay/...tail/1033.html
1994 Honda Accord Stereo Wiring
Constant 12V+ Blue/White
Switched 12V+ Yellow/Red
Ground Black
Illumination Red/Black
Dimmer n/a
Antenna Trigger Yellow/White
Left Rear Front Speakers 6 1/2"
Doors
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers 6" x 9"
Rear Deck
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
