94 radio wiring
Old Feb 7, 2012 | 07:59 PM
tedmar's Avatar
Default 94 radio wiring
Well i took out my factory radio and cut the clip i have done this in other cars before. But after hooking up my old cd player it seems it is not being grounded and the front speakers wont get power at all the backs do but are very quiet due to no ground but this all worked on factory radio is it the cd player it self or something i messed up pls help i have no music.
Old Feb 7, 2012 | 08:41 PM
tedmar's Avatar
Anybody pls
Old Feb 7, 2012 | 10:37 PM
Sorry, I am confused. Did you cut the factory electrical connector and directly wire to the new cd player?
Old Feb 7, 2012 | 11:21 PM
Cody_754's Avatar
Almost A Senior Member
I made the same mistake on my 97 accord. I cut the factory radio harness and tried to install my new radio (which didn't work). I later found out that there was a $15 harness connector I could've bought and just plugged my new radio right in. I would check your local auto parts store (or walmart) and see if they have a connector for your accord. They had one for mine which I could've used if I knew about it.
Old Feb 8, 2012 | 07:09 AM
How about I move this over to A/V Elect.
Old Feb 8, 2012 | 07:20 AM
crispin's Avatar
Do not cut the harness from now on, not only does it make it harder on you it is also frustrating to whomever buys the car from you.
here is the wiring colors for your car.
1994 Honda Accord Stereo Wiring Information
Old Feb 8, 2012 | 04:58 PM
tedmar's Avatar
Those color codes are not matching up with my car
Old Feb 8, 2012 | 05:47 PM
tedmar's Avatar
Well i got power to my cd player it is on i hooked up my speakers as it says. My right rear works but i must have volume up all the way to barely hear it. And they are the only ones working pls help guys.
Old Feb 8, 2012 | 07:18 PM
neophyte's Avatar
My suggestion would be wiring your factory harness back in. then buying the adapter.
Old Feb 9, 2012 | 07:23 PM
tedmar's Avatar
Thank you every body for the help i relized the prior owner rewired the harness thats why to colors were wrong also my cd player was broken bought a new one works perfect thank you evrybody
rhodesmk
Sep 11, 2008 03:52 PM
Karl`
Feb 27, 2008 06:37 PM
cman
Feb 9, 2008 08:08 PM
Ruppe
Aug 9, 2006 11:00 PM
Ruppe
Aug 9, 2006 10:59 PM
