95 gauge cluster problem
Old Jun 7, 2009 | 10:07 PM
95aclx
Default 95 gauge cluster problem
I recently got a 95 accord lx bone stock and love it. The only problem is the speedometer seems to work only when it wants to. Everything else like rpm, gas etc always works but the spedo doesn't. I't either works or jumps up to 20 when i turn the key and stops. Any ideas?
Old Jun 8, 2009 | 08:17 AM
Is the check engine light on? Its usually one of two things, either the VSS(vehicle speed sensor) is broken or the speedometer itself is broken.
Old Jun 8, 2009 | 09:42 AM
00AccordLX5spd's Avatar
Registered User
Does the cruise control work when the speedometer is malfunctioning.
If the cruise control DOES work all the time:
It is likely the speedometer motor itself. The same thing was happeneing to my wife's 95 EX before we traded it in. I did lots of research and the answer I kept coming up with was that it was the speedometer itself. You will likely need to remove the cluster and send it to a speedometer repair shop. I never did mine because I did not want to have to remove the entire dash to get the cluster out.
If the cruise control DOES NOT work when the speedometer is not working:
It is likely the VSS - a MUCH easier fix.
Old Jun 8, 2009 | 10:00 PM
95aclx
No the check engine light isn't on but the cruise does always work... so maybe it is the speedometer. Thanks
Old Jun 9, 2009 | 10:01 AM
Registered User
Eeegghhhh....if the cruise works all the time it is more than likely the speedometer itself.
You may want to call around town and get quotes on speedometer repair. If no one around town can do it, there are shops you can find on the internet that will fix it for around $100. You have to pull the cluster out yourself though and ship the whole thing to them.
There are also ebay sellers that sell clusters. Many of them will roll the mileage to whatever you want it rolled to (if you want it to reflect the same thing your curent one does.) If you do that, it would be a good idea to take a picture of your old cluster next to the used cluster showing the mileage of both at the time the swap is performed. The ebay cluster will probably be cheaper, but you do run the risk of it not working......
Old Jun 9, 2009 | 08:22 PM
95aclx
Thanks 00accordlx5spd that's what i was hoping i didn't have to do lol.
Old Jun 10, 2009 | 11:29 AM
Registered User
If I had not traded in the 95 Accord, I was going to go the eBay route. I was finding clusters in the $40 range.
Old Jun 13, 2009 | 11:24 PM
Kamisamanou
It is definitely the guage cluster, you can't replace the speedometer individually. I recommend doing it yourself, you'll save about a hundred dollars. I did the same for my 94 LX model.
Old Jun 14, 2009 | 12:28 AM
95aclx
Thanks. Is there a right up anywhere on how to fix it anybody know?
Old Jun 15, 2009 | 11:56 AM
Registered User
Well it would just be a matter of take the old cluster out and replace with a working cluster. A haynes manual can tell you how to remove the cluster. there are free online manuals in teh DIY section as well.
sumpump_1203
Feb 28, 2015 12:32 AM
ryandavis33
May 17, 2011 06:13 PM
steviebix
May 6, 2007 01:32 AM
dcrusupra
Jul 19, 2006 02:24 AM
marbro
May 20, 2006 10:13 PM
