annoying rattle
Old Jun 8, 2007 | 05:37 PM
thug@$$n1gga
Default annoying rattle
sup
my memphis subs hit pretty hard in the trunk of my 94 ex and the bump rattles the antenna in the back. I know about dynamat but how the crap to you fix your antenna rattling?? (its one that goes in and out) when i hold it with my hand the bass sounds 100x better.
any ideas
Old Jun 8, 2007 | 05:46 PM
sir_nasty's Avatar
Default RE: annoying rattle
A couple of options... if you don't use the antenna then just disconnect the power wire so it won't come up and rattle, if you do use it then consider going to an aftermarket one.... those would be the easiest suggestions....
Old Jun 8, 2007 | 06:26 PM
thug@$$n1gga
how bad would disconnecting the wire affect my radio signal?
Old Jun 8, 2007 | 06:54 PM
MacLeod's Avatar
Dynamat and a lot of it.
Remember - you can NEVER have too much damping.
Old Jun 14, 2007 | 07:34 PM
karlneff
Try inserting some rubber grommets into the mounting bolts - cuts vibration a lot!
Old Jun 14, 2007 | 11:40 PM
tru_44's Avatar
maybe your antenna needs to be tightened or try aftermarket antenna that is stationary.
stonesfan
Sep 9, 2010 04:54 PM
botang47
Feb 5, 2009 10:13 PM
Patrick
Oct 5, 2008 04:06 PM
thunder_x
Oct 22, 2007 04:35 PM
chibiko
Mar 19, 2007 04:03 PM
