Best Location for Bluetooth Microphone?
Old Mar 5, 2012 | 09:08 PM
MysticBlueEX's Avatar
Almost A Senior Member
Default Best Location for Bluetooth Microphone?
I am planning on installing a BT Head Unit and I need suggestions on where to place the microphone. The JVC unit does not have a press button on the remote mic, so it doesn't need to be convenient, I was thinking of somewhere along the driver side A pillar, or perhaps where the blank cutout is for the Fog Lamp switch.
I am thinking that I might need to remove the plastic cover from the A pillar to rout the cable. Any suggestions, I would like it to be semi hidden.
Old Mar 6, 2012 | 07:03 AM
crispin's Avatar
The sun visor works the best - IMHO
Old Mar 6, 2012 | 09:30 AM
keep_hope_alive's Avatar
agreed, away from the window as much as possible. the center light/holder is a good spot also.
Old Mar 6, 2012 | 10:23 AM
OK If the center light/holder is the best place
would I tuck the cable under the A pillar then under the edge of the headliner to get to that spot?
Any tips on removing the edge of the trim pieces, to conceal the wiring?
I know I could get them off, but putting trim back on so that it LOOKS like it was never were removed is the problem that I would have.
Old Mar 6, 2012 | 10:36 AM
crispin's Avatar
would I tuck the cable under the A pillar then under the edge of the headliner to get to that spot? YES
It goes on real easy, I have taken mine on and off a few times.
Start pulling on the top edge and work your way to the bottom.
To put it back on, you have to pull the door molding back a bit so the pillar cover goes under it, get the tension clips lined up to the holes in the A- Pillar and use your palm to tap it in.
Sounds harder than it is.
Also it is possible to run the wire without removing the cover
Old Mar 6, 2012 | 02:01 PM
Thank you.
Thursday morning Piece o' Cake!
samhurst
Jul 12, 2011 12:51 PM
archadian465
Aug 15, 2009 05:14 PM
DougHood
Mar 26, 2006 03:48 PM
BMattox4
Mar 6, 2006 12:36 AM
DougHood
Jan 18, 2006 10:27 PM
