Can my standard headunit be changed?
Old Feb 25, 2008 | 01:02 PM
Faz's Avatar
Faz
Default Can my standard headunit be changed?
Im from Uk (England) and own a Honda Accord CL7.
I was wondering if it is possible to change the headunit. Im assumingthat thewhole dash would need to be removed? Am iright in saying this?
Let me know
Thanks
Faz
Old Feb 25, 2008 | 03:34 PM
klrspz's Avatar
Default RE: Can my standard headunit be changed?
Yes.. please search as there are many threads on this (i just searched for "headunit" as one word and found the answer you were looking for at least 15 times)
Old Feb 25, 2008 | 04:42 PM
00AccordLX5spd's Avatar
Registered User
A quick answer to your question is yes, the headunit can be changed.
You do not have to remove the dash. The old unit comes out, and the new unit goes in place of the old unit. If you buy online, you should buy from a place (such as crutchfield) that will give you an installation kit with instuctions. I replaced one on one of my Mustangs by myselfwhen I was 16 years old.
Old Feb 25, 2008 | 04:48 PM
klrspz's Avatar
https://www.hondaaccordforum.com/fb.asp?m=96100
on the newer accords the dash does need to be removed, as well as a dash kit replaced if you want it to house in the existing dash location the OEM headunit sits... otherwise there is a bay kit you can buy but imo looks tacky.
all options are detailed in this thread: https://www.hondaaccordforum.com/m_73427/tm.htm
you can also check the gallery link in my SIG (not on the profile section of HAF, I haven't uploaded all my images as of yet) to see my installed radio..
It took me literally 30-45 minutes to do the entire swap, most of it was soldering the new wiring harness.
Old Feb 26, 2008 | 09:09 AM
Registered User
ORIGINAL: klrspz
Dang that sucks bad!
Sorry for the misinformation I gave above.
Leave it toHonda to make a job that should be easy to do a royal PITA.
Old Feb 26, 2008 | 09:29 AM
klrspz's Avatar
It's not too bad compared to a few rides i've changed radios in... it all comes apart elegantly, so it's ok...
93Accord2.2
Nov 6, 2013 11:53 PM
Chris Jameson
Feb 19, 2013 06:39 AM
87hatchback
Sep 21, 2007 12:12 AM
t00fatt
Dec 25, 2006 08:12 PM
ivrex
Nov 19, 2006 11:29 PM
