Cannot Turn ON The Bluetooth on 2013 Honda Accord LX
Old Feb 13, 2015 | 08:06 PM
northwoodshyun's Avatar
Default Cannot Turn ON The Bluetooth on 2013 Honda Accord LX
I have a 2013 Honda Accord LX with 57,000 miles, which was purchased new in November 2012. The car has been very good without any electrical or mechanical issue until a few weeks ago. I was trying to use the Bluetooth feature but the car says its Bluetooth is "OFF". I went to the "Settings" but the Bluetooth ON/OFF feature has been grayed out. The built-in Bluetooth feature was functional a few weeks ago prior to this observation.
I got the radio head unit into a diagnostic mode and it shows "B1775" but the "OK" string is missing. It should have displayed "B1775 OK". I ordered a used 2013 Bluetooth module (Honda part# 39770-T2A-A81) from eBay and just waiting for it to arrive. I will post once I get the replacement unit installed and whether the issue is related to a non-functional Bluetooth module. I thought the Bluetooth modules are fairly robust. Hopefully the Bluetooth module is plug-n-play with the head unit and no additional programming is required.
I had a number of issues related to the head units in previous Hondas so no big deal.
Old Feb 14, 2015 | 12:03 PM
Default It Works!
I got a replacement Bluetooth module this morning. It was a simple plug-n-play and no programming required. The Bluetooth is now fully functional and can be turned ON/OFF via "Settings". The Bluetooth from the eBay was only $55 compared to $214 from the Honda dealer.
Attached Thumbnails Cannot Turn ON The Bluetooth on 2013 Honda Accord LX-p1000172.jpg   Cannot Turn ON The Bluetooth on 2013 Honda Accord LX-p1000173.jpg   Cannot Turn ON The Bluetooth on 2013 Honda Accord LX-p1000174.jpg   Cannot Turn ON The Bluetooth on 2013 Honda Accord LX-p1000175.jpg   Cannot Turn ON The Bluetooth on 2013 Honda Accord LX-p1000176.jpg
Old Feb 23, 2015 | 06:01 PM
keep_hope_alive's Avatar
so the previous owner removed the BT module or disconnected it? or it failed?
Old Feb 23, 2015 | 08:29 PM
I am the original owner of the car. Bought it new with 5 miles on. The original Bluetooth module failed so I had to buy a new one. I guess these Johnson Controls made Bluetooth modules for Honda have some reliability issue; this issue has been well documented in Acurazine forum. I am sure I just got unlucky.
Old Oct 19, 2016 | 11:53 AM
Brian Hoke's Avatar
My bluetooth on/off has greyed out as well. I also got into diagnostic mode with info from another thread and got the B1775 without an OK next to it. I have ordered a used hft module from ebay for $73 and have removed the old unit. Ready to plug and play other module. Fingers crossed. The dealership was gonna bend me over!
Old Nov 28, 2016 | 09:24 PM
bummer news. i need to pick up a BT module to go with my swapped touchscreen, good to know several may be needed.
Old Jun 3, 2018 | 03:37 PM
pakr's Avatar
Default Location of HFT bluetooth module in honda accord 2013
My bluetooth module gave up on my honda accord 2013 and now does not turn on. I can't seem to find where the module is located in honda accord 2013. Any suggestions?
Old Jun 4, 2018 | 11:45 AM
the module is directly underneath the radio. you can access it by removing the lower pocket. This is done by popping the silver trim off the sides of the console (lift up at the rear first and pop up as you work to the shifter then pull back near the pocket).
the pocket is held with screws on each side.
the module is a PITA to access given the inverted location but you can see the screws with a mirror. The ANC module is also there and if you search for "Accord ANC Removal" you will find other threads and videos detailing the process.
Old Jun 9, 2018 | 06:57 PM
pakr's Avatar
That worked perfectly.. It was not as bad as I thought it would be.
Old Apr 25, 2019 | 03:47 PM
@SouthernFinancialSolutions's Avatar
I bought this vehicle a year ago and the previous owner told me they were having issues with the bluetooth. They took it up to the dealership and the dealership told them the repair would be $800. They asked what other option they had and the dealership recommended removing the bluetooth. Glad I found this remedy! Thanks!
sonicmoj
Sep 23, 2013 09:45 AM
AccordEXLV6
May 11, 2013 08:21 PM
manincity
Aug 19, 2011 02:27 PM
skyview222
Aug 6, 2011 01:38 PM
FatCat
Jun 2, 2011 06:13 PM
