Car stereo question
Old Jul 25, 2010 | 12:52 PM
ecomajor's Avatar
Default Car stereo question
My cassette player keeps on switching back and forth all of sudden since last week. I cant get any cassettes to work on it. So I wanted to switch it for with a different stereo. I have a 97 accord dx. I found a stereo for a 92-95 Honda Civic. Will that be a direct fit, or will it not work?
thanks
Old Jul 25, 2010 | 02:04 PM
g22cd5's Avatar
Supper Moderator
you can make any radio work pretty much it’s all in the wiring and how it fits in your dash. I’d say go for it..cus I was gonna do the same thing I had a ej8 radio I wanna gonna swap in my cb7 b/c it would have look\ed supper clean and OEM-ish. But I have to have a cd playr and this one was only a radio and thats all.
Old Jul 25, 2010 | 07:52 PM
ecomajor's Avatar
Default but this radio comes with no instructions
Will it be plug and play if its from a civic or will I have to mess around with the wires. As the radio I see on ebay has no manual so I have no idea what wires goto where. Also where is a good place to find out how to take out the original radio from my accord?
thanks
Old Jul 26, 2010 | 12:47 PM
keep_hope_alive's Avatar
a Haynes manual can tell you how to remove the factory radio, and also give you the wiring diagrams.
the radio harness should be the same, but it might not be a direct fit (though most of them were a single DIN size back then - the mounting brackets may be different). I recommend just buying an aftermarket tape deck (with Metra 70-1720 harness adapter) if you require cassette playback and cannot find a same year/model replacement.
Old Jul 27, 2010 | 12:16 PM
ecomajor's Avatar
Default found wiring diagrams but.....
I found the wiring diagrams for my car, however, none of them include the factory cd changer that is in my trunk. How do I then know which wires from the leftover wires go where?
Old Jul 27, 2010 | 05:05 PM
the changer typically has it's own plug, separate from the normal stereo wiring. is the factory harness cut off?
if you want the CD changer to work - i recommend getting an exact replacement.
pejaypreston
Mar 22, 2008 03:55 PM
FlikDaBean
Jan 17, 2008 07:08 PM
tru3_k177
Jan 4, 2008 10:45 PM
dhenson
Feb 2, 2007 06:40 PM
lukpoiwai
Mar 5, 2006 01:13 AM
