Gound Points
Old Apr 4, 2013 | 10:19 PM
gillman331's Avatar
Default Gound Points
I need two good grounding points for my amp and my capacitor. I'm installing them in the trunk of my 91 Honda accord LX does anyone know of a good place to ground these. I was reading and it says that it needs two separate grounds any help would be appreciated!
Old Apr 4, 2013 | 10:33 PM
neophyte's Avatar
the floor of the trunk works pretty well. DONT DRILL THE GAS TANK THOUGH.
Old Apr 4, 2013 | 10:52 PM
There are already ground bolts on both sides of the trunk near the tail lights if you remove the panel covers.
Old Apr 7, 2013 | 10:11 AM
keep_hope_alive's Avatar
the issue with the factory ground points are they are on vertical metal pieces that are tack welded in place. you want the floor because it has better welds from front to back.
simply mask off a small square the size of the ring terminal(s). sand away all paint to expose shiny metal. then remove the tape and drill a hole in the middle (check underneath for access first). then use a 1/4-20 or similar bolt and nut (nut and threads inside the car). lastly , silicone over the exposed bolt head under the car.
Old Apr 7, 2013 | 10:46 AM
Attached Thumbnails Gound Points-accordtrunk0809011.jpg   Gound Points-accordtrunk0809013.jpg   Gound Points-accordtrunk0809010.jpg
accordfan222
Mar 25, 2007 12:40 PM
tucsonsx
Feb 7, 2007 12:31 AM
mckeand13
Nov 21, 2006 01:33 AM
LeakinLX
Jul 6, 2006 11:24 PM
drs
Dec 12, 2005 03:59 PM
