head unit install, need help asap
installing an alpine ida-x305 and i need to know if i need to splice off of the 12 volt power cable to power both the alpine deck and the stock headunit because i have dual climate.
EDIT:
i guess i should make it clear that i don't know exactly which cables that are inside the car do exactly what. i can read what they do on them.
basically i'm wiring up the harness that came with the head unit after removing poorly installed line out converters
EDIT:
I'm not really sure what your doing or working with, but yes the radio and headunit will need to be connected to power. The kit to install it should have came with a harness that splices into the car harness leaving the stock radio plugged in.
everything went swell the first time around (not so bad if i say so myself considering its my first time.)
though now comes the mounting into the cubby hole kit and i can't figure out how to keep the head unit from just coming out of the kit.
what i can't figure out is how to put the braces or whatever on it.
I'm not familiar with the kit, but you will use either a DIN cage or brackets that bolt onto the side of the radio. It's probably a cage if you can't figure it out, you basically slide the cage in from the front, then bend the tabs down to keep it from coming out, then slide the radio into the cage.
yeah i'm pretty damn infuriated with these idiots they hire at best buy.
and as far as wiring up the head unit. are crimp caps better than electrical tape?
AND... lol i can't be 100% but i wanna say the sound isn't as clear with the new head unit. sure that annoying hiss is gone and the sub sounds 110 thousand times better. i'm just iffy on whats coming out of the speakers.
I always put 2 layers of electrical tape and liquid electrical tape when I wire stuff. The tape can and will unravel over time, but the liquid tape will seal it all up. I love the stuff! But it takes about 15 minutes to dry which is forever when putting a head unit in!
