Help replacing the tweeters on a 2003
Old Dec 13, 2007 | 11:32 AM
Pearl's Avatar
Default Help replacing the tweeters on a 2003
I'd like to upgrade my factory speakers with aftermarket good stuff. Should I be able to buy component speakers for the front and have the tweeters fit in the stock spot or would I need to do some sort of modification to the stock area?
Old Dec 13, 2007 | 11:58 AM
finch13's Avatar
Default RE: Help replacing the tweeters on a 2003
Please post your year/model/trim/engine in your sig. If your car has tweeters already you should be able to replace them, if not I don't believe it's too hard to install them into the door panel.
Old Dec 13, 2007 | 12:31 PM
falkore24's Avatar
not all tweeters fit. I custom mounted mine to the back of the grille.
Old Dec 13, 2007 | 02:44 PM
Pearl's Avatar
In the dash or in the door?
Old Dec 13, 2007 | 03:00 PM
magiconthetire's Avatar
If its a 03+ its in the dash
Old Dec 13, 2007 | 04:19 PM
Pearl's Avatar
ORIGINAL: magiconthetire
So what would be involved in putting aftermarket tweeters there? Does one brand work/fit better than any others? I get the feeling this might bea totally custom deal depending on which brand I go with.
Old Dec 13, 2007 | 10:30 PM
if you go to www.crutchfield.com, then click out "outfit my car" it will tell you all the speakers that can fit in your factory locations. As far as brands go, i would suggest spending the extra money and getting a name brand such as Infinity, Polk, Memphis (there are many others). Its all about the sound that you like. Just don't waste your money on junky ones, you just wont be happy in the end.
I honestly dont know what is involved in installing in the dash location. I have an 05 and i replaced the speakers in the doors and rear deck myself, but i left the tweeters alone. I would only suggest going about the tweeter replacement if you really want to, and are an audiophile. I didnt think it would be worth it for my tastes. You might be better off keeping the factory tweeters and getting a nice 2 way 5.25's for the doors.
Old Dec 17, 2007 | 01:40 PM
Pearl's Avatar
but will the factory tweeters still work?
Old Dec 17, 2007 | 08:10 PM
Yes, your factory tweeters will still work, you honestly cant even tell they are there in the first place.
Old Dec 18, 2007 | 04:06 PM
Pearl's Avatar
True
