helping find an accessory wire for interior neons
Old Oct 2, 2008 | 01:27 PM
falkore24's Avatar
Default RE: helping find an accessory wire for interior neons
They are from NEC for buildings. The wire rating comes ONLY from the insulation temperature rating. As noted, the values are conservative, but good for size selection. These are applicable for any voltage because a wire size correlates to the amperage, not voltage.
Old Oct 2, 2008 | 08:42 PM
botang47's Avatar
http://www.accessafuse.com/access.htm
that looks like its it. it looks pretty good.
whats the difference between a normal one and a mini?
which one should i get for a 2001 accord?
Old Oct 2, 2008 | 08:54 PM
t00fatt's Avatar
I believe you need a mini for the inside fuse box, feel free to correct me guys if I'm wrong.
Old Oct 3, 2008 | 07:23 AM
falkore24's Avatar
They make a better connection, but if the main fuse blows, you have to replace it with another one of those .... that's why I like the other type better, standard fuses.
Old Oct 3, 2008 | 10:00 AM
botang47's Avatar
but will a standard one fit in the fusebox?
Old Oct 3, 2008 | 11:05 AM
falkore24's Avatar
The 2 types are the same size .... you can bend the tab so the new connection lies flat across the top of the other fuses .... bend it with the female connector in place to make sure there's enough room for it. Also, make sure it's an insulated connector.
Old Oct 3, 2008 | 11:15 AM
  #17
finch13's Avatar
ORIGINAL: falkore24
[sm=nono.gif] Aaron, Standard Blade fuses and Mini-Blade (ATC) fuses are not the same size. 6th gens use the Mini-Blade fuses while 5th gens use standard. So, to the OP, you want the Mini (non-folding ones) from that site.
Old Oct 3, 2008 | 03:15 PM
  #18
botang47's Avatar
thanks finch, i totally would have bought standard if you hadnt of told me
Old Oct 3, 2008 | 03:21 PM
  #19
falkore24's Avatar
What I meant is the special fuse with the hot lead and the regular fuse with the blade adapter are the same .... not full size and mini.
You need mini type as noted ..... either adapter system would work, but I'd recommend the one that uses standard fuses. Both can be bent flat.
Old Dec 13, 2008 | 11:52 AM
  #20
bmwproboi05's Avatar
just go to autozone an get the mini add a circuit line like this one http://www.bussmann.com/images/3c2dc...86ccd13aad.JPG.
make sure of which one you need for some use regular size fuse an others use mini. i used this to hardwire a radar detector, gps, and a remote wire for amp
