honda accord 2000 wont start after install a back up camera
hello,
I have a 2000 honda accord. few day a go I decided to install a back up camera.
First try, i blow up the back up and instrument light, my car have some difficulty with start.
second try, I connect acc wire from the camera to the Ig wire at the stereo, the back up light on the back now on and I could not start my car.
I do back and unplug them all.
My car still did not start. I checked all the fuses and they were all fine.
Any idea? please help....
ok, I just googled it. if the accord is like the civic, it would seem that it may not have a relay. here are some instructions on finding out if it is the starter. if it isnt in the starter you probably have a short.
2001 civ not starting (starter relay??) - ClubCivic.com - Honda Civic Forum
do you have a dmm?
do you have a dmm?
this is what was in the link that I was talking about.
The starter has a simple circuit. If the click you hear is definitely coming from the starter solenoid, which is built into the starter, then check voltage at the large white wire that runs directly from the battery to the starter motor. Also clean and tighten the white wire where it connects to the starter.
and I dont know why that is underlined but I cant make it go away.
I guess what I am getting at is the starter clicking? it doesnt seem that there is a relay. either way what you can do is pull that wire. and check it to see if it is hot when you turn your key. if not the problem is further up the line. a haynes manual would really help so you could track the wire starting at the solenoid back up to the ignition switch and find out where you loose the signal.
i second using a service manual to understand the wiring of the car. there is a sticky in this section where i link to an electronic version of our car's service manual. first, verify all fuses are ok, use a test light to test the fuse (touch both metal tabs visible when fuse is inserted). if you get voltage on one tab but not the other - the fuse is bad.
it is unlikely you damage a relay during your installation, but likely you shorted out wiring. did you tape up and insulate all wiring you touched/cut?
