how to remove panel under steering wheel - and good/bad re: fm modulator?
Old Jul 26, 2011 | 10:12 AM
sacrider's Avatar
Default how to remove panel under steering wheel - and good/bad re: fm modulator?
I've got a 2007 Accord VP with the stock single cd stereo. I need to remve the panel under the dash to wire up my scangauge mileage computer, but can't figure out how to remove this panel.
Also, I'm looking to add an input for mp3/ etc to my stock stereo. It looks like the hardwired fm modulators are cheap and easy to install, but I also see more expensive options that seem to plug directly into the stereo. Is there a significant sound quality difference between the two types of products? If I'm plugging into the headphone jack on my mp3 player, doesn't that lose alot of sound quality also?
Old Jul 27, 2011 | 09:13 PM
keep_hope_alive's Avatar
if your factory head unit has an XM button, then you can add an aux input with no loss in sound quality. FM modulators will result in lower sound quality and noise. some are better than others, and include a switch to activate and selectable frequencies. Clarion FM200 works well.
usually, the panel is held with screws on the door side (Behind a removable fuse panel) and in the middle, covered by the center console trim.
Old Jul 28, 2011 | 09:43 AM
sacrider's Avatar
Thanks K.H.A. - my stereo doesn't have an "xm" button, but it does have a "cd/aux" button - the middle of three buttons on the left of the screen. I've seen you mention Pac-audio in other posts, and GROM mentioned as well. They both say their units should work on a 2007 Accord, but they don't specify the "VP" model. I'm hoping my "cd/aux" button will give me the ability to use one of these products.
Thanks for the tips on the fm modulator and the panel removal.
Old Jul 30, 2011 | 05:24 PM
there are so many Honda radio options in the past 10 years, it's hard to keep up. i need to find a master compatibility chart or something. i can't get my hands on every year/make/model.
giulio76
Dec 29, 2012 11:16 AM
nontimor
Dec 14, 2011 05:24 PM
dunkinidaho
Jun 25, 2011 05:05 PM
zzzz
Jul 4, 2006 05:08 AM
