huge static noise after audio install
Old 06-02-2018, 06:14 PM
dohcvtec's Avatar
Default huge static noise after audio install
Hello everyone,
2012 Honda Accord Coupe V6
I installed new radio, rear speakers, box with 2 subs and amp. 0 Gauge cables for positive and negative. After everything is attached there is a huge static. Here are pictures of what I did and I'll post 2 videos. Please help me out. Trying to figure it out for a week
Thanks in advance.
Old 06-03-2018, 06:31 AM
Seanjordan20's Avatar
Is that the poorer cable running with all the other cables. It should have been ran separately. I sounds you are having an emi issue
Old 06-03-2018, 06:15 PM
dohcvtec's Avatar
I'm sorry, which "poorer" cable are you referring to that should have been ran separately?
Old 06-03-2018, 06:20 PM
It was suppose to be power cable. I am referring to the cable running to the trunk
Old 06-03-2018, 06:25 PM
dohcvtec's Avatar
so you think if I run it separately it will stop?
Old 06-03-2018, 06:46 PM
You always run your power cable separately to avoid emi or get better speaker cables. You might have a few things wrong with the install but I can't make it out with the pics
Old 06-03-2018, 07:35 PM
dohcvtec's Avatar
okay. i will redo the cables. thank you
Old 06-03-2018, 08:23 PM
I'll moved this thread to the Audio/Visual electronic section. KeepHopeAlive (KHA) is the moderator/ resident expert; so, hopefully he may also chime in.
Issue may also have something to do with the Active Noise Cancellation (ANC) of the car.
Old 06-03-2018, 08:28 PM
dohcvtec's Avatar
Thank you and I'm sorry that I posted in wrong section. as you can see I'm brand new and in a hurry to fix it.
ANC - is that constantly connected or how does it go? not familiar with that. I thought that if it's not plugged in to the radio it's not active. Same as the stock microphone.
Old 06-03-2018, 08:38 PM
See this thread regarding ANC:
https://www.hondaaccordforum.com/for...ing-sub-40076/
That probably is your issue due to the sub.
Quick Reply: huge static noise after audio install
