instructions on removing door panel
Remove the two screws behind the plastic door that is behind the inside door handle. Then starting at the bottom left of the door panel, pry the panel from the door making your way all the way around releasing all the clips. Then lift the panel up and off the door, and disconnect the cable going to the inside handle, be careful not the brake the clip. Its pretty simple just be gentle and if you feel resistance you may have missed a clip. I hope this helps!
New2JDM
Apr 1, 2012 07:53 PM
mergliaa
Jan 10, 2009 05:45 PM
