Jesus Help!
Old Jan 31, 2008 | 12:16 AM
Mark_H's Avatar
Default Jesus Help!
OMFGoodness! Alright Guys, I Have Never Ever Needed Your Help More Than I Do Now! Alright For Some Reason, Some Time Ago (3 Days), My Radio Stopped Working. It Is A Cheap JVC But Still. The Eject Turns The Radio On Temporarily, But Then It Turns Off Right After It Ejects The CD. It Will Also Turn On When I Click The "Check Time" Button - But Again Only Temporarily. I AM GOING CRAZY!! I Need To Be Able To Listen To My Music! Please Help!
Old Jan 31, 2008 | 12:20 AM
Mark_H's Avatar
Default RE: Jesus Help!
Here Is A Pic Of The Radio!
Old Jan 31, 2008 | 10:04 AM
t00fatt's Avatar
Sounds like your radio is broken or you've got a bad connection on the switched ignition wire(usually red). Those functions of the radio work when the key is off and it draws power from the constant on (usually yellow). So its possible the radio is only getting power from the constant hot(yellow) and not from the switched hot(red). Pull the radio out, get a volt meter, turn the key to "ON" then check the voltage at the switched(red) wire. If there is no voltage you've got a blown fuse somewhere. If there is voltage you've got a bad connection or a bad radio.
Old Jan 31, 2008 | 07:11 PM
Whitefoxx's Avatar
whats the big deal, just go get a new head unit, this time do it right, get a ALPINE
Old Jan 31, 2008 | 10:47 PM
kingpin
You can do a quick test for a hard reset. Just hold the power button and the eject button at the same time for about 5 seconds with the car on. If that doesn't do anything the you will need to test the wires to make sure you have power.
Old Feb 1, 2008 | 12:57 AM
Mark_H's Avatar
How do i checfk the voltage? Or wires?
Mark_H's Avatar
How do i check the voltage? Or wires?
Old Feb 1, 2008 | 01:04 AM
Nova's Avatar
Wait wait... Stop.
Check your RADIO fuse under the dash AND under the hood. If both are good, then take the Stereo out and check the fuse behind your Stereo plug (has an average of 16 plugs on it) and check the fuse in there. If that is fine, then get a PROBE light indicator or a 12 volt Digital Multi Meter (DMM), turn the ignition to ACC, or if yourcar is different, thengo to"Run", THENcheck the RED Wire on the plug that was previously in your stereo. If it shows 12volts or makes the Light light up, then you have yourself a wasted stereo.
Old Feb 1, 2008 | 08:10 PM
MacLeod's Avatar
Chances are the radio is toast.
If a fuse is blown it wouldnt come on at all.
Good news is, this is a great excuse to upgrade!!
Old Feb 1, 2008 | 10:52 PM
pham9006's Avatar
im down with whitefoxx and macleod..
brandon0409
Feb 15, 2014 06:36 PM
Levibyz
May 31, 2011 09:43 PM
mamtsberg
Mar 17, 2010 09:15 PM
joshk5145
Mar 9, 2008 09:00 PM
