radio
Old Nov 19, 2010 | 09:43 PM
I-reef's Avatar
Default radio
Is this a good radio for a 2000 accord ex? http://www.amazon.com/gp/product/B00...ef=oss_product, I bought it with out thinking about asking about it. Would it be hard to install one of these on my own like could i get it done in a day?
Old Nov 20, 2010 | 08:12 AM
Looks like a good product for a Honda Accord.
It can be done in a day. The biggest challenge is removing the trim pieces w/o damaging/breaking them. Take your time! Suggest downloading a shop manual from Online Manuals DIY links to help you understand what needs to be removed and to guide this task. Check DIY links for help w/ trim removal. It's similar for all Accords. Check youtube for possibility of a video of someone doing this job.
Even if you don't get finished car would be driveable w/ trim removed until you finish. Not pretty but functional.
Old Nov 23, 2010 | 12:44 PM
keep_hope_alive's Avatar
you can get instructions for removing the factory radio here:
https://metradealer.com/files/products/INST95-7895.pdf
two screws under the trim piece, one behind the clock/hazard assembly (pops out to reveal screw).
with the trim piece loose, disconnect the A/C control harnesses.
four 10mm bolts hold in the factory radio.
You'll need the wire harness adapter
Metra 70-1721
And a mounting kit
Metra 99-7895
If you buy from Crutchfield, all of the necessary mounts and harnesses and instructions will be included for FREE - and you get a warranty.
Old Nov 23, 2010 | 12:47 PM
i could do it in about 30 minutes. the most time is spent connecting the new radio harness to the Metra wire harness (just matching colors, solder, heatshrink). if you don't solder, good crimp connectors and heat shrink is also acceptable.
Do not cut the factory wire harness off. Do not just twist wire and wrap with electrical tape. A good mechanical connection is required. Electrical tape is fine for an outside bundle wrap,but heat shrink and zip ties are better. Tape comes off and leaves a sticky residue.
Old Nov 24, 2010 | 02:02 AM
I-reef's Avatar
Ohhh, I forgot to post I finished the project, I had the guys at Best Buy do the wiring for me for free and bought the deck kit and put it in myself. It really did take about 30mins to take it apart and put it back together.
djaycardona
Nov 26, 2013 04:07 PM
GMANCRX
Jul 15, 2013 02:50 PM
RecMK5
Feb 13, 2009 06:33 AM
Jeff247
Mar 28, 2007 04:22 PM
vaughnsimon
May 21, 2005 05:36 AM
