Stereo/Wiring
Old Sep 5, 2011 | 05:58 AM
  #21
piggylover1985's Avatar
Ok, do you have a test light ? Pull the unit out and check your power wires, and also make sure that your ground is good.
Old Sep 5, 2011 | 09:09 AM
  #22
AckerVTEC's Avatar
No i do not have a test light :/ but i do have a volt meter. Should i try switching the two honda power wires?
Old Sep 5, 2011 | 09:19 AM
  #23
Just make sure both power wires have 12v and all grounds are good
Old Sep 5, 2011 | 10:07 AM
  #24
AckerVTEC's Avatar
the grounds are connected but neither of the power wires are reading 12v when i use the meter...
idk whats wrong
Old Sep 5, 2011 | 10:15 AM
  #25
Check all the wires, there should be 1 constant 12v and another 12v with key on. If not check for blown fuse.
Old Sep 5, 2011 | 10:25 AM
  #26
You can always run another wire from battery positive to the radio, jump the 2 positive wires from the radio into the 12v from battery to test the radio.
Old Sep 5, 2011 | 10:29 AM
  #27
AckerVTEC's Avatar
which fuse/fueses would i check for the wires to the stereo and which box/panel are they located ?
i wouldnt know what i was doing to try the wire to the battery thing you mentioned. I have a feeling its the fuses
Old Sep 5, 2011 | 12:28 PM
  #28
Check fuse number 9 passenger side
Old Sep 5, 2011 | 10:21 PM
  #29
AckerVTEC's Avatar
So i think we may have found the issue lol fuse number 9 on passenger side is a little yellow 20amp and its black in the middle and the wires busted lolz so ill need a new fuse...
should solve the prob?
Old Sep 6, 2011 | 05:28 AM
  #30
Put a new fuse in with the same rating and find out, make sure none of the tripped wires are touching ground or metal, that will cause a short and take out the fuse again.
