Stereo won't work after installation of new battery
Old Dec 2, 2011 | 05:23 PM
maichou87's Avatar
Default Stereo won't work after installation of new battery
I changed my battery last night and this morning, when I tried my radio out for the first time since the battery switched, there was nothing on the screen except for the clock. That A/C and heater adjuster appeared okay. I can adjust and fix the clock without any problem but there's no sound, no words not even a prompt for the code for my stereo! Does anyone know what happened? Any advice would be very much appreciated, thank you.
Old Dec 2, 2011 | 05:31 PM
neophyte's Avatar
have you tried disconecting and reconnecting the battery?
Old Dec 2, 2011 | 05:46 PM
maichou87's Avatar
Yes, I just did that. I unplugged the (-) for about ten seconds, but it's still the same. Should I unplug it and leave if off for longer?
Old Dec 2, 2011 | 05:56 PM
neophyte's Avatar
try an hour or so. that should allow enough time for the radio to reset. if that does not work i am not sure other than did you push the power button to turn the radio back on?
Old Dec 2, 2011 | 06:30 PM
maichou87's Avatar
I didn't know there's a power button? Let me do that first, if nothing happen then I will leave the off for an hour. I'll let you know what happens, thanks.
Old Dec 2, 2011 | 08:07 PM
neophyte's Avatar
power button on my is right in the center of the volume ****.
Old Dec 2, 2011 | 10:12 PM
keep_hope_alive's Avatar
We don't know the year or trim level. More infor please, including what stero option you have.
Old Dec 2, 2011 | 10:29 PM
neophyte's Avatar
you are correct sir. I assumed that it was a 7th gen cause he made it sound as if the ac display, clock, and stereo were all in the same screen. I probably should not have done that.
Old Dec 2, 2011 | 10:37 PM
Your assumption is likely correct, but we'll verify anyway.
Old Dec 3, 2011 | 09:51 AM
maichou87's Avatar
Its a 2008 honda accord and I feel so stupid but I figured out what the problem was. It wasn't even turn on!!! Btw, I am a girl. Thanks you guys for all the tips!!!!!
