sub and amp for 09 accord
Old Dec 26, 2011 | 05:54 PM
catalyst686's Avatar
Default sub and amp for 09 accord
I have 2 infinity 12" subs, along with a 1200 watt amp and cap, I'm wondering if I need to get a new deck for the car for the components to work. It seems like it would be a little tricky to have an aftermarket deck because the stock cd player and everything else are so close together. I'm sure someone knows the answer to this, or someone has done it. Thanks for the help!
Old Dec 26, 2011 | 06:10 PM
crispin's Avatar
no you do not need a new deck
You need a Line Out Converter - about $10 on ebay
take you cap and throw it in the trash as they are complete garbage and do nothing at all.
Here is my Honda
Old Dec 26, 2011 | 08:42 PM
neophyte's Avatar
you dont need one but your post is confusing. the deck is the cd player unless you have an external disc changer.
Old Dec 27, 2011 | 09:32 AM
crispin's Avatar
you will need this, it ties into the speaker wires and gives you the RCA output that will then go to your amp
RAPTOR LOCA25H ADJUSTABLE 2 CHANNEL LINE OUT CONVERTER | eBay
Old Dec 27, 2011 | 06:14 PM
keep_hope_alive's Avatar
Old Jan 3, 2012 | 11:46 AM
Sparkknocker's Avatar
Originally Posted by keep_hope_alive
I am installing two Rockford P3's and a Rockford 1000w mono sub into my factory 07 Honda Accord. I want to keep the oem stereo. Will this LOC work with this setup? Seems to have a lot of wires coming off it. Sorry, I'm a noob when it comes to radio stuff. Thanks
I already bought a Scosche LOC80 but I know the quality of Scosche can be quite poor: http://www.amazon.com/Scosche-2-Chan.../dp/B00009UHRE
Old Jan 3, 2012 | 11:59 AM
crispin's Avatar
I already bought a Scosche LOC80 but I know the quality of Scosche can be quite poor: Amazon.com: Scosche Loc80 2-Channel Adjustable Lineout Converter: Car Electronics
Yes it will work fine.
It is pretty easy to install
Old Jan 3, 2012 | 12:37 PM
drew&dixon1718's Avatar
if u go to ur local car audio shop they can give u a loc then and there it may cost more but if u dont wanna wait then its worth it. i got 2 kicker comp 12s in my 04.
Old Jan 3, 2012 | 06:15 PM
Just make sure the LOC has an auto turn on if the amp doesn't.
No amp should be triggered by ignition alone.
Old Jan 3, 2012 | 06:46 PM
neophyte's Avatar
know what you are looking for though. just because it is more doesnt mean it is better. most of the shops around here sell ones that are half as good as a pac oem and about twice the cost.
