subwoofers draining battery?
when i first installed my amp and sub system, everything was fine. about a week later my car had lost all battery power, so i had to jump it(with subs still attached). it ran good for about another 3-5 days and the battery was dead again, so i jumped it once more.
after speaking with my dad he said that the amp/subwoofers were draining my battery, he suspected it was because i have my aftermarket alarm system boltedadjacent to the power supply to my amp on the terminal, with no insulator in between the two connections ever since the second time i completely unhooked the amp power supply wire. any suggestions on how to re set up the two connections to my battery? (this may be hard to understand. i tried my best to explain the situation) |
RE: subwoofers draining battery?
look up "Big 3" ..... there is a battery terminal referanced in there that has the connections that you need.
Get a new battery.
An amp shouldnt drain a battery unless youre playing your system for a couple hours with the engine off. |
ORIGINAL: MacLeod An amp shouldnt drain a battery unless youre playing your system for a couple hours with the engine off. |
^^^^ yes u can, but that would depend on the batt or batts you are usin and the voltage the amp is pullin. The battery problem could be a cause of a bad batt or maybe your amp is not turning off when u turn off your car, some lower brand amps are known to do that.
Ive got close to 1000 watts in my system and I have the stock battery and I routinely sit in my car for 1-3 hours tuning and Ive never had a problem.
Granted Im not blasting it with deep bass music tho and these are brand new batteries but you get the point. Ive got a friend that has over 4000 watts in his system with a stock battery and we've sat inside for an hour or more tuning before and it cranked right up. |
did u hook up the remote power switch from ur deck to ur amp? little blue wire, look for the place on ur amp.
yeah, i've hooked up everything properly.
well if everything is hooked up right. its gotta be ur amp, do u have all electrical connections wrapped? what kind of amp?
So whats the word on the battery? Is yours an old one or a new one?
