subwoofers draining battery?
Old Dec 4, 2007 | 09:46 PM
BallaxB09's Avatar
Default subwoofers draining battery?
when i first installed my amp and sub system, everything was fine. about a week later my car had lost all battery power, so i had to jump it(with subs still attached). it ran good for about another 3-5 days and the battery was dead again, so i jumped it once more.
after speaking with my dad he said that the amp/subwoofers were draining my battery, he suspected it was because i have my aftermarket alarm system boltedadjacent to the power supply to my amp on the terminal, with no insulator in between the two connections
ever since the second time i completely unhooked the amp power supply wire.
any suggestions on how to re set up the two connections to my battery?
(this may be hard to understand. i tried my best to explain the situation)
Old Dec 5, 2007 | 06:58 AM
falkore24's Avatar
Default RE: subwoofers draining battery?
look up "Big 3" ..... there is a battery terminal referanced in there that has the connections that you need.
Old Dec 5, 2007 | 05:02 PM
MacLeod's Avatar
Get a new battery.
An amp shouldnt drain a battery unless youre playing your system for a couple hours with the engine off.
Old Dec 5, 2007 | 05:41 PM
vtecHef's Avatar
ORIGINAL: MacLeod
You can really get a couple hours out of you battery with the motor off and subs/amp/speakers playing ? I thought like 20 min max ?
Old Dec 5, 2007 | 06:31 PM
tru_44's Avatar
^^^^ yes u can, but that would depend on the batt or batts you are usin and the voltage the amp is pullin. The battery problem could be a cause of a bad batt or maybe your amp is not turning off when u turn off your car, some lower brand amps are known to do that.
Old Dec 6, 2007 | 11:25 AM
MacLeod's Avatar
Ive got close to 1000 watts in my system and I have the stock battery and I routinely sit in my car for 1-3 hours tuning and Ive never had a problem.
Granted Im not blasting it with deep bass music tho and these are brand new batteries but you get the point.
Ive got a friend that has over 4000 watts in his system with a stock battery and we've sat inside for an hour or more tuning before and it cranked right up.
Old Dec 6, 2007 | 11:48 AM
94Honda's Avatar
did u hook up the remote power switch from ur deck to ur amp? little blue wire, look for the place on ur amp.
Old Dec 6, 2007 | 03:20 PM
BallaxB09's Avatar
yeah, i've hooked up everything properly.
Old Dec 6, 2007 | 10:04 PM
94Honda's Avatar
well if everything is hooked up right. its gotta be ur amp, do u have all electrical connections wrapped? what kind of amp?
Old Dec 7, 2007 | 06:25 PM
MacLeod's Avatar
So whats the word on the battery? Is yours an old one or a new one?
