Voltage Issue
Old Apr 12, 2011 | 11:53 AM
ShadowWolf9's Avatar
Default Voltage Issue
I'm having a voltage problem with my 2009 Accord. I have a voltmeter and it has been going wild for the past 2 weeks. In the past my voltage was ALWAYS at a solid 14.50v. Now it sits at 14.20 while dropping to 12.40 for 15 minutes and maybe shooting back up in seconds, then dropping again, ect.
Not sure what the issue is. I only have a JL 500/1v2 amp so that's definitely not the problem. Plus the issue persists even after I turn my music off.
Could there be something wrong with the battery/alternator?
Old Apr 12, 2011 | 12:26 PM
There is a load detector circuit that drops charging load when electrical load is low to improve fuel economy. It's been around for a long time. I don't remember it going low for that long, but might w/ a good battery.
Old Apr 12, 2011 | 01:53 PM
neophyte's Avatar
could also be a sign that your alternator is going out.
Old Apr 12, 2011 | 03:46 PM
Idk if it would start doing that all of a sudden after having the car for almost 2 years. Especially since it stays the same even when I crank my music.
Maybe I'll get the alt tested at my local shop.
Old Apr 12, 2011 | 07:58 PM
keep_hope_alive's Avatar
I agree that the ELD will do that, it turns the alt off while driving based on the ignition load. You may not have noticed it or you had enough ignition load to prevent it from turning off. See my thread on the subject in this section. Next time it drops, turn on the fan, that ignition load will turn the ELD back on.
Old Apr 13, 2011 | 08:46 PM
I think that was the problem. My voltage will drop to 12 and then I'll turn on the air for it to shoot up to 14.2v.
This probably won't happen when I have the SAZ-1500D in there...
Thanks guys!
Old Apr 13, 2011 | 11:40 PM
It will happen regardless of you amp since the amo isn't wired through the ELD, nor could you. See my ELD bypass thread for a work around.
deserthonda
May 10, 2008 10:39 AM
GLENN1965
Nov 18, 2007 06:22 AM
AyashiFX55
May 31, 2007 11:57 PM
mikebrawn1
Apr 30, 2007 12:14 AM
asilomar244
Feb 1, 2006 05:29 AM
