What sound settings do you use ?
Old Jan 11, 2012 | 12:22 AM
hazeces's Avatar
Default What sound settings do you use ?
I have an 03 Honda Accord LX.
I don't have an aftermarket stereo, but I'm thinking of getting one since I'm tired of making freaking CD's all the time. Anyway, with the factory stereo and no aftermarket speakers, subs, amps on your stereo what sounds setting do you use?
Old Jan 11, 2012 | 12:30 AM
Talking Hi Member
There are no certain sound setting to set your system to other than to where your ears like the sounds your putting out..
Old Jan 11, 2012 | 09:41 AM
neophyte's Avatar
flat is really where the speakers are made to play +1 on either should not run into much problem with distortion.
Old Jan 14, 2012 | 07:58 AM
keep_hope_alive's Avatar
your real issue is if you can even remove the factory radio. if climate controls are integrated then you have to add one in the pocket below. if the climate controls are ***** then you can buy a replacement dash piece that gives you a standard opening and gives you new A/C *****.
visit Metraonline.com and enter your vehicle information.
each head unit you can buy has different sound shaping options. there is no general rule for what sounds better with factory speakers. usually, just having a better stereo makes the stock speakers sound better.
mruhl4
Aug 24, 2008 12:11 PM
mruhl4
Aug 24, 2008 12:08 PM
jon02accord
Mar 26, 2008 10:54 AM
Rasher
Oct 12, 2007 07:28 AM
Triblade
Mar 16, 2006 11:13 AM
