Wiring Diagram for Head Unit
Old Jan 17, 2015 | 08:31 PM
prvoigt's Avatar
Default Wiring Diagram for Head Unit
Hi,
I'm installing subs in my daughters 2005 Accord Hybrid.
The only part that I'm stuck on is installing the Line Output Converter on the factory Head Unit.
This thing has 6 different plugs w over a dozen wires in each.
Does anyone have a wiring diagram and/or which of the plugs do I look for the rear speakers?
The HU is Model No. 39175-sdr-a210-m2 (HONDA PART No. : 7BO0)
Thank you in advance for your help!
Old Jan 17, 2015 | 08:59 PM
Honda image of locations of radio connectors for the 2005 Hybrid looks a little different than the photo that you posted from cd4car website.
The rear speaker wires are at the 20-P light blue harness connector that plugs into the black connector (Connector A).
6 BLU/WHT (LR (+))
16 BLU/BLK (LR (–))
5 PNK (RR (+))
15 BLU/YEL (RR (–))
Old Jan 18, 2015 | 11:21 AM
prvoigt's Avatar
Default Awesome!
Thanks redbull. That's exactly what I need!
Yes, the radio pictured is not the same exact one, but it's close enough and has the same plugs.
What about the remote power wire? Is that also in the same plug? Which wire?
Old Jan 18, 2015 | 11:43 AM
Are you referring to the power wire for the audio unit, when the ignition is switched to ACC or ON?
If so, that would be on the same connector.
2 YEL (Fuse 32 – Under-dash)
Old Jan 18, 2015 | 11:52 AM
You may want to use a different fused slot in the under-dash fuse box if that is for a remote power wire for an amp.
Old Jan 18, 2015 | 12:38 PM
prvoigt's Avatar
Yes, that's the one.
Is there any advantage to wiring it to the fuse box as opposed to splicing into the power wire from the Head Unit?
Old Jan 19, 2015 | 01:42 PM
keep_hope_alive's Avatar
no real benefit, i typically tap the radio ignition wire and put a fuse holder in-line with a 1A fuse.
garyrocky1
Feb 15, 2014 10:11 PM
rqboarder43
Aug 26, 2010 01:03 PM
alexdc
Jun 16, 2010 07:17 PM
rpreziosi
Jan 2, 2010 09:27 PM
HAcc407
Mar 6, 2006 03:30 PM
