Canada, Over Seas & Elsewhere Not from the states? Everywhere else post here.
what is the largest tire on 19x8.5 45-ET wheel
Old Jun 20, 2014 | 02:18 PM
Hot Brass's Avatar
Default what is the largest tire on 19x8.5 45-ET wheel
Hi What is the largest tire(s) I can use with a 19x8.5 wheel with a 45 ET on a stock suspension 2013 Touring with no drop,without any rubbing issues? I have seen all the on-line tire/wheel comparator,but I need 'first hand' info. Will a 245/40/19 fit with no worries on a squared set-up on 19x8.5 wheels?Thanks,HB
Old Jun 20, 2014 | 02:48 PM
shipo's Avatar
While I have no first hand experience with your car, the specs indicate 245/40 R19 tires should fit your car with no problems.
Old Jun 20, 2014 | 04:00 PM
Hot Brass's Avatar
Thanks. Honda has an optional HFP wheel for the Accord Coupe which is a 19x8.0" 55 offset,with a 245/40R19 tire,but I want to go to 8.5 inch wheels with 45 offset,so the whole assembly will stick out an extra .643", almost inline with the fender lip on the front.....don't want any rubbing going over bumps on a turn?!
What size tires are you guys running on your Canadian Touring's?HB
Old Jul 13, 2014 | 06:02 PM
Hot Brass's Avatar
Any Canadian Touring's running larger than the factory 235/45R18 tires and a lower than stock (lower than 55 ET?)Thanks,HB
Old Jul 13, 2014 | 07:35 PM
shipo's Avatar
When you say "larger", are you asking if folks are running tires "wider" or "larger diameter"?
Old Jul 14, 2014 | 06:10 AM
Hot Brass's Avatar
Sorry...I meant both,wider and larger diameter,but lower than the 55 stock offset,with no rubbing. Thanks,HB
shhhua
Jul 3, 2010 06:44 AM
wgbm92
Feb 6, 2010 09:34 PM
lippstuh
Oct 10, 2008 11:57 PM
jblaust
Jun 1, 2008 11:13 PM
millpond
Jan 23, 2007 08:08 PM
