General Scratch
Old Feb 21, 2008 | 07:31 PM
dubjdub
Default General Scratch
What products should be used to remove or minimize scratches? The car I just bought has some scratches that I would like to remove when the weather gets right. Any suggestions will be appreciated. Thanks!
Old Feb 28, 2008 | 10:31 AM
02Hawkord's Avatar
Default RE: General Scratch
I like using Adam's detailing wax. Also Zaino. Both come with 3-4 step processes in waxing your car and that should help remove alot of small scratches. Also try getting a 3-speed buffer and using that to take the wax off also helps remove slight scratches.
Old Mar 1, 2008 | 08:12 PM
Meguires has a product called scratch out that seems to work pretty good also...
Old Mar 2, 2008 | 09:26 AM
RTexasF's Avatar
Super Member
I believe it is Scratch X.
Old Mar 3, 2008 | 02:10 PM
dubjdub
thanks guys for the info. when the weather is nice, i will check out everything.
Old Mar 13, 2008 | 08:31 PM
zam17's Avatar
you may use any scratch removers but some of them do not work.. you may also use a plastic polish formulated to cure this problem. I've tried Meguires - Scratch X - it works pretty well on my car parts, its available on almost car parts store so you'll have no dificulty in finding one. Good luck
HundaAccode
Jul 30, 2007 03:03 AM
Nightbreeze
May 10, 2007 03:00 PM
fireballer44
Jul 26, 2006 11:02 AM
solidsnake
Mar 30, 2006 06:14 PM
maahsredsox
Jan 12, 2005 10:42 PM
