Do-It-Yourself Section This section is for requests for DIY help, not for general technical advice.
Rear seat removal 2005
Old Dec 29, 2009 | 02:19 PM
overdbars's Avatar
Default Rear seat removal 2005
I have searched the posts & have not found enough information.Need to remove the rear seat in a 2005 Accord LX. (lost ring wedding ring down the side). I also have a 1990 Accord & it is not the same after 20 years. Any info on the removal of the "05" rear seat would be appreciated.
JD
Old Dec 29, 2009 | 03:44 PM
Talking Hello New Member
If no one has the answer by tonoght's end, then I would suggest you stop by your car dealers body shop..and let them show you how..shouldn't take to much time to find out..
Happy Holidays !
Old Dec 29, 2009 | 03:46 PM
Talking Hello Again Member
I also see that your from Nevada..so here is a flag for you
Old Jan 4, 2010 | 07:24 AM
Maybe this picture will help? The trick is compressing the seat so you can find the bolt #30 & get a wrench on it. Remove that & I THINK(?) the seat moves forward to unhook the front edge.
Old Jan 5, 2010 | 06:42 PM
overdbars's Avatar
Default Removal of rear seat on 2005 Accord
Rear seat removal 2005-05accord-003.jpg This is the bolt which will need to be removed. Using a 10mm socket with a 6" to 8" extension will work.
Rear seat removal 2005-05-accord-002.jpg This keeps the seat inplace. The bolt goes...you guessed it, thru the hole.
Rear seat removal 2005-05accord-004.jpg (On the drivers side of the car) push the seat down & seat back up. Located the 10mm bolt head.
Rear seat removal 2005-05accord-006.jpg Locating the 10mm bolt
Old Jan 5, 2010 | 07:07 PM
overdbars's Avatar
Default Part 2 seat removal 2005 Accord
Rear seat removal 2005-05accord-007.jpg Location of Bolt
Rear seat removal 2005-05accord-001.jpg There are two tabs located on the rear seat. They are on the front of the seat. one on each side of the seat & kinda of hidden. This might require you to lift up on the front part of the seat to locate the tabs.
Rear seat removal 2005-05accord-005.jpg Once you located the tabs you can push down on the seat while pulling the tabs forward. The seat should release then.
Rear seat removal 2005-05accord-009.jpg This is just another look at the bracket which the 10mm bolts goes thru to hold the seat in place.
To re-install push the seat back in place. I did not set the seat so the front tabs were re-set. Instead I placed the seat in place & fastened the 10mm bolt down first thinking it would be easier so I could move the seat if needed. My way was a pain but it did go back together after lining the bracket up using a long screwdriver. Anyway there you go. I do have to thank the guy's @ Findley Honda in NorthWest Las Vegas for the information. They were willing to remove the seat on site but I couldn't let them. If they did then what kind of SHADE TREE MECHANIC would I be.
Old Jan 5, 2010 | 07:17 PM
overdbars's Avatar
Default Rear Seat
Found Missing Ring & Am Now the Man Of The Day
There are no smiley Faces big enough for the reward which I will be getting tonight.
Drive Safer
JD
Old Jan 6, 2010 | 06:54 AM
Good pictures; thanks for letting us know how it goes. I think I'll move this to the DIY section since your photos will probably help other people who have to do this.
spectre184
Jun 23, 2007 03:30 PM
Cash4
May 20, 2007 04:45 PM
Dannok
May 11, 2007 11:45 AM
Dannok
Mar 23, 2007 05:12 PM
anhvi3t228
Mar 16, 2007 12:54 AM
