07 accord strong vibration at idle
Old Apr 30, 2021 | 10:16 AM
Proskow's Avatar
Originally Posted by JimBlake
What NGK plugs did you use? I'm not sure what your car calls for.
Have you taken off the air duct & looked into the throttle body? If the PCV system isn't working well, it can build up oily gunk in the throttle body & intake manifold. Maybe that needs to be cleaned out?
They were iridium but not the top tier ones. The car did this shudder shaking sensation before I did the plugs. I already cleaned out the throttle body and sea foamed the engine . Idles better but this weird mini stroke it has still exists .
Old May 2, 2021 | 09:02 AM
I was looking for the specific number. I think your car calls for IZFR6K-11 (or -13?) spark plugs. I'm not sure what you mean by top-tier, or what the difference might be. NGK's website probably says something about the actual differences.
Old May 2, 2021 | 09:17 AM
Proskow's Avatar
Hmm I see. Like I said the car had the same symptoms before I even changed the plugs. Also I noticed the other day I started the car and put it reverse right away and it did it and almost seemed like it wanted to stall was odd.
Old May 4, 2021 | 02:04 PM
rtosborne's Avatar
It could be a motor mount or mounts going bad. You don’t realize how much vibration they damp until they fail. I know it sounds silly, but it can give the impression the engine is running rough or missing.
They are also pretty easy to inspect/test.
Good luck.
Old May 4, 2021 | 07:52 PM
Proskow's Avatar
Good luck.
Thank you.
Yes that could be it possibly. I changed motor mounts on a 95 jeep last year and did make a big difference for vibration wise.
wegipip
Jan 2, 2017 11:37 AM
96cord
Dec 31, 2014 09:16 AM
ocoF23A1
Dec 30, 2014 10:31 PM
arcticf1re
Apr 9, 2010 10:14 PM
superballz00
Oct 25, 2007 01:18 AM
