180,000 mi engine and how to keep it running well
Old Aug 5, 2006 | 01:29 AM
bpo145's Avatar
Default 180,000 mi engine and how to keep it running well
The engine on my 96 2.2 5 speed has a bit over 180,000 miles on it. What should be done to keep the engine running smooth other than what has been done for the past 10 years. Thanks
Old Aug 5, 2006 | 04:26 AM
legionofone's Avatar
Default RE: 180,000 mi engine and how to keep it running well
ok... go out to some road REALY FAR OUT! and take off ur exaust and intake manifolds... and turn ur car on... dont touch the pedal or anything... just have fun with that
Old Aug 5, 2006 | 12:51 PM
deserthonda's Avatar
I do not know what has been done for the past 10 years ...........
but make sure oil and filter is changed 3-3.5k miles
tranny fluid. if auto every 15k if manual every 30 k
plugs every 30k miles
valve adjustment ever 30k miles
fuel filter every 30k miles
air filter every 15k miles
coolant every 30k miles
timing belt every 70-80k miles when doing t-belt, replace water pump, cam, crank, balancer shft seals. alt, p/s belts
tire rotation every 7.5k miles
replace all the coolant hoses , radiator, heater and bypass hoses , if it has not been done yet , they are almost 11 years old..
any time you ( shop ) are doing on oil change . make sure to chk all the underneath . cv boots, p/s rack dust boots,ball joints upper and lower. chk how the tires are wearing , oil leaks, coolant leaks , brakes, if something is needed today do not postpone too long to replace it or it might cost more money later
main thing is not to abuse the car,
Old Aug 5, 2006 | 02:59 PM
RTexasF's Avatar
Super Member
Along with following DH's expert advice I would treat it twice with Auto-Rx. You can read more on the Auto-Rx site or go to Bobistheoilguy.com and read the hundred or so positive results from those that have used it. There are some before and after pictures of the internals too. I'll begin the treatment in both of our cars @ 50,000 miles.
Here's some pics a BITOG member took of how well the product cleaned his engine:
http://www.auto-rx.com/rms13/index-2.htm
Old Aug 5, 2006 | 06:02 PM
lightshow's Avatar
yea just change the oil and everytime you change the oil put some sort of fuel treatment in there. im still using all the original fuel system components and i have 260k on my car
Old Aug 5, 2006 | 08:16 PM
mbo1985's Avatar
exactly. Keep that oil changed (never ever miss one or put it off! ) and take care of the fuel system; you'll be driving that car a long time!
Old Aug 6, 2006 | 10:43 PM
bpo145's Avatar
I have had the car in the family for its entire life. I get any work done at the same dealer of purchase which has a great service department. I have done all the normal repairs and replacements listed below but the honda tech which i know personally said the cv boot and the A-pipe should be replaced but could be held off for a little while. I dont want to wait too long. Also what type of fuel treatment should i use. thanks
Old Aug 6, 2006 | 10:49 PM
fireballer44's Avatar
If the CV boot is cracked I would replace it immediately. Otherwise, dirt and debris will get to the joint and it will eventually fail.
Old Aug 12, 2006 | 09:34 AM
RTexasF's Avatar
Super Member
ORIGINAL: bpo145
For over the counter treatments Chevron's Techron is very effective. I attended a school for Yamaha engines and witnessed first hand how well it works but it does need to be in a high concentration if you have never used a fuel system cleaner before. Buy enough to treat the entire tank not just a few gallons. Run the treated tank until it's as close to empty as you are comfortable with before adding more fuel. Repeat about every 3-4K.
Charlie Moua
Jul 27, 2012 03:30 AM
SevenFour
May 18, 2012 12:33 AM
RA1525
Mar 17, 2011 02:10 PM
Willb2305
Oct 27, 2009 08:13 PM
Mar 6, 2007 08:27 PM
