1991 Accord 180,000 miles...AC bypass belt
Old May 17, 2012 | 10:37 AM
SevenFour's Avatar
Arrow 1991 Accord 180,000 miles...AC bypass belt
Greetings,
So it's been 7 years since the AC was turned on...cause it ran outta gas and I never bothered to add more to it again since it runs on environmentally harmful CFC gas and I tolerate heat well. Anyways, I'm just going to rid the entire AC compressor that's attached to the engine block and run the serpentine belt straight from the crank pulley to the alternator. Will I run into vibration issues with the weight of the ac compressor not being there anymore? Will the rpm of the alternator change?
Feedback would be appreciated.
Old May 17, 2012 | 10:44 AM
SevenFour's Avatar
It's a manual transmission 2.2L SOHC 1991 Accord
Old May 17, 2012 | 10:59 AM
moey's Avatar
The RPM of the alternator would not change that is determined by the size of the crank shaft pulley which is dictated by the engine speed. I cant imagine it throwing the engine off balance, they used to offer models with and without A/C they didnt have anything special to balance the engine if you opted out of A/C.
Old May 17, 2012 | 04:21 PM
SevenFour's Avatar
That sounds logical moey. I can't wait to rip that AC compressor from the engine block.
Old May 18, 2012 | 12:33 AM
So get a belt from an Accord DX; I think that version didn't have AC. That belt should be the right length for what you're doing.
RA1525
Mar 17, 2011 02:10 PM
bigstinker
Feb 27, 2010 02:16 AM
Willb2305
Oct 27, 2009 08:13 PM
Mar 6, 2007 08:27 PM
bpo145
Aug 12, 2006 09:34 AM
