1993 car 1991 engine
Old Dec 20, 2008 | 01:55 PM
therickster
Default 1993 car 1991 engine
Here's the deal we have a 1993 accord 2.2 auto trans. Blown engine ! I found a 1991 engine that we are putting in car. The 91 engine that is being put in car has coil pack built into dist. cap and the 93 coil and dist. cap are separate. Which dist. should I use?
Thanks!
Rick
Old Dec 21, 2008 | 11:36 AM
Default RE: 1993 car 1991 engine
This is a question for one of our motor heads...PM hondadude and see if he has the correct answer for you...
Old Dec 21, 2008 | 11:39 AM
Use the one from your 93. It should bolt in fine, and will work correctly with your wiring harness. If you were to use the internal coil distributor you would have some wiring issues(believe me i've been there and its not somewhere you want to go)
CB7-SE-1991
Jan 29, 2013 04:45 PM
Mikebike125
Dec 6, 2009 08:39 PM
SE_Accord 93
Aug 17, 2009 05:19 AM
hatzipri
Jul 10, 2008 12:22 AM
arffam1
Sep 6, 2005 11:31 PM
