2000 accord ran out of oil.
Old Nov 6, 2008 | 07:03 PM
benzeye
Default 2000 accord ran out of oil.
I just bought a 2000 honda accord, 4 clyinder with a 5 speed. I purchased the car not running, when I started to dig into it i found that the cam gear was spun off and the head was locked up, and no oil in the crank case, I know my way around a v8 well but this is my first import. Im still trying to decide if i should try to rebuild this motor or ive been looking into an h22 swap. do any of you guys have any info on what my best option for a motor swap would be? I would like the car to be fast, good gas milage, and still a daily driver. Also do any of you think i would be lucky enough to put a head on it and be ok.
Old Nov 6, 2008 | 08:38 PM
t4lude98's Avatar
Default RE: 2000 accord ran out of oil.
well i say pull the oil pan and check out everything down there and decice if youwant to try a to fix
but if you go with a swap i would go with the h22
emilyi08
May 23, 2011 01:52 PM
19Accord97
Sep 7, 2006 11:53 PM
ricksaccord
Feb 27, 2006 03:35 AM
ricksaccord
Feb 26, 2006 03:23 PM
