2001 f23a1 low compression in cylinder 3
Old Jul 26, 2011 | 11:49 PM
masterjp92's Avatar
Default 2001 f23a1 low compression in cylinder 3
Hi guys. im new to this forum so please bare with me. I have a misfire in cylinder 3 in my 4 cyl accord. i got a compression test and cylinder 1,2, and 4 all had 220 psi while cylinder 3 was running at 120psi. Hondas requires a minimum of 135psi in a cylinder. Any way i can increase the compression in that cylinder? car has 134,000 miles on it.
Old Jul 27, 2011 | 07:04 AM
g22cd5's Avatar
Supper Moderator
your rings on the piston are bad or your losing compression from through your valves in that cyl. You need to do a leak down test to be 100% sure
rederik13
Apr 6, 2012 10:49 PM
jimz
Jan 4, 2012 11:18 AM
accordracer
May 11, 2010 03:43 PM
parallax
Jun 26, 2007 11:22 AM
GringoEJS
Jul 3, 2006 10:17 PM
