2004 accord coupe 2.4 i-vtec DOHC
Old Mar 13, 2013 | 11:30 AM
KB/K24's Avatar
Default 2004 accord coupe 2.4 i-vtec DOHC
Where is the fuel pressure regulator located?
Goin to buy an after market one to bring up the pressure to get better top end
Old Mar 13, 2013 | 05:37 PM
In the tank.
Old Mar 14, 2013 | 09:35 AM
KB/K24's Avatar
Is there a way to bypass so I can stick a regulator on the fuel system?
Old Mar 14, 2013 | 06:29 PM
Not really sure?
From what I can see in pic's.....you might be able to cap the "vent". It looks like the regulator is maybe "spring driven" and once the pressure pushes the spring back the fuel is just vented back into the tank.....
So could you thread a screw/bolt into the vent? Can you "jam" the spring so it does not move?
Might be worth a bone yard run and pull a regulator from another 7th gen and do some playing around with it? I would try getting the whole pump as they will know that is worth $$'s. If you remove the reg from the pump and "check out" with just it, they might not even know what it is and let you go for $5~$10....just a random little valve off a Honda?
PS- Highly suggest a shop manual for the car.......for ~$22 you can download a pretty good one (for ~$27 you can get a CD shipped) and I'm not talking a chilton or haynes.
Accord16_Al
Aug 17, 2011 02:22 AM
cg31998
Dec 15, 2010 10:29 AM
JDM Nagoya
Jun 4, 2010 01:08 PM
redbull622
Oct 23, 2009 05:06 PM
PTVDesign
Oct 28, 2008 09:20 PM
