2006 Accord rpm fluctuation
Old Jan 9, 2015 | 04:55 PM
c.odonnell's Avatar
Default 2006 Accord rpm fluctuation
I purchased a 2006 Honda Accord with the 3.0L V6 V-Tech engine about 18 months ago. It currently has 141,000 miles on it and all service is up to date as far as I know. I have noticed the rpm gauge fluctuates but only at a very specific point. When the transmission is in 5th gear and the rpms are about 1500 and I am traveling at about 45mph the rpm needle will bounce about 50 rpm's every 5 seconds. The car is up to temperature when it does this but it will stop after about a half hour of running. I live in Minnesota and it has been very cold here. I never noticed this when it was warm out but I wasn't looking for it either. Has anyone else had a problem like this? Could it be an ignition coil problem? I had read a few posts that were similar but had a very large rpm fluctuation and the replies had indicated an ignition coil issue.
Old Jan 9, 2015 | 06:50 PM
From your description, suspect the lockup torque converter is locking/unlocking. This will cause an rpm swing of 50-150 rpm depending on engine load.
Do you have a Check Engine Light? An electrical fault in the lockup solenoid circuit would set a code.
If not, it may worth asking Honda to see if there are any TSB's that might address your problem.
mpanelli
Nov 7, 2014 10:41 PM
dacecil
Aug 29, 2007 10:30 AM
fperezal
Jun 14, 2006 05:03 AM
Norway
Apr 15, 2006 03:33 PM
Trens
Aug 3, 2005 03:22 PM
