91 Honda accord faster?
Old Jan 7, 2008 | 07:11 PM
Royal089's Avatar
Default RE: 91 Honda accord faster?
Oval mostly but from time to time its alot of turns
Old Jan 7, 2008 | 08:20 PM
nafango2's Avatar
accords, along with all fwd vehicles have massive understeer as far as high-speed handling is concerned. if you really want to make a track car pick a rwd car or do a rwd conversion (all custom fab, very hard to do. if you had the ability you wouldnt be asking this question right now)
unless its a fwd only series. then you need a turbo. superchargers will rob a ton of horsepower before they create any with these small engines.
although superchargers are a tad more reliable and predictable.
Old Jan 7, 2008 | 08:24 PM
Royal089's Avatar
we do straight aways also what turbo would have to be used?
Old Jan 7, 2008 | 08:38 PM
nafango2's Avatar
well no turbo would "have" to be used, but i would recommend putting some forged pistons + rods along with a T3/T4 turbocharger running around 15-17psi max boost. (any higher and you will have to use racing gas... $$$)
of course i make it sound super simple, but you would need to upgrade a LOT to run that much, but not too much as far as track day cars are concerned.
if its automatic, swap it to manual. costs a grand or two to do it, but you can sell the parts from the automatic for about $600 total, so you can make a lot of that money back.
as far as a turbocharged H22 is concerned, screw that. H22 sucks as far as boost is concerned. if you want 450+ whp, when you put in forged pistons and rods put in some 10.5:1-11:1 compression pistons along with an H22 headswap and ECU swap and knock sensor. BAM you get all the power that the H22 produces, without the drawbacks of weak sleeves.
Old Jan 7, 2008 | 08:40 PM
Royal089's Avatar
thanks appreciate it
Old Jan 7, 2008 | 08:42 PM
Royal089's Avatar
oh and real quick do you know a link so i can read up on this because i dont really know what to type in to find
Old Jan 8, 2008 | 02:12 AM
  #17
benjiaccord's Avatar
[/quote]
Okay, I know that right out of the box that the H22 is not the best turbocharged motor, however I have seen, albeit in a magazine, a eg civic running a boosted h22 and squirting i believe a 200 shot. The thing was boosting around 28 lbs so said the article and with the squirt they were making just over 900 whp!! That's insane! They used it strictly for 1/4 mile though. They said the only draw back was hooking up with that much power.
I thought it was all bs until they actually showed dyno sheets of the thing. it was something like 580lbs of torque and 903 whp *with the nitrous*
So, if built correctly, an h22 can take boost to crazy amounts, but honestly you might as well save your money and just build the sohc which has lower compression. It's cheaper that way
Old Jan 8, 2008 | 07:15 AM
  #18
BlkCurrantKord's Avatar
Oh geezus....[sm=headbang.gif]
What engine is currently in your car? Auto or manual.
Old Jan 8, 2008 | 07:09 PM
  #19
Royal089's Avatar
my car has auto with manual capable
Old Jan 8, 2008 | 08:18 PM
  #20
nafango2's Avatar
"Manual Capable"
i side with kord.
when people build H22s to turbocharge them, most people have the resleeved. stock sleeves cant handle too much boost. thats why their bad for boosting. the reason they produce more hp is primarily due to the compression ratio. you need to run some seriously high octane gas in order to run high levels of boost along with high compression pistons, or else youll get detonation up the ying-yang.
Armani
Jan 6, 2014 05:18 PM
redbull-1
Jul 28, 2013 12:34 AM
m1sch1efmayhem
Jul 18, 2008 12:52 PM
Leonhartilly
Jun 22, 2007 01:28 PM
jmcmichael08
Sep 15, 2006 07:08 PM
