92 accord wont start
Old Jul 9, 2011 | 07:11 PM
bigpat's Avatar
Almost A Senior Member
Exclamation
If it was a brownish green color, I would say that is the antifreeze and rust solution from the radiator. Could be a bad hose, or leaking radiator core. Check the coolant level with the engine cold and off, and never open the cap when the car is warmed up or overheated. Put your fingers into the puddle and see how thick it is. Does the leaking fluid feel oily or more like water ?? I really suspect you need to get the car to the radiator shop to get a new core for the radiator. You will need new hoses...upper and lower, and a new thermostat as well. The parts aren't very expensive, so do all of it at once. Just my .02, Good Luck !! Hopefully, the waterpump isn't worn out.
Old Jul 12, 2011 | 04:05 PM
MyHonda92's Avatar
it was more oily there is no more coming out the puddle was pretty big. ill keep all that in mind and get it all on pay day. thank you!!!
Tony1M
Nov 6, 2023 08:29 PM
jimmy3fingers
Oct 4, 2013 08:02 PM
gasface11
Jul 11, 2012 12:33 PM
MrGmo
Sep 28, 2007 01:40 AM
booter
May 11, 2005 02:26 AM
