94 accord ex automatic not starting!
Old Oct 15, 2011 | 09:06 PM
Jap.Doe's Avatar
Default 94 accord ex automatic not starting!
So my 94 accord ex isnt starting. Its truning over so its not the starter, i just replaced the ignition system, and battery is charged, i cant figure out whats wrong. My dash is flashing D4 and engine light after trying to start it. It was having trouble earlier this week when i was driving, it wouldnt grip the gear it was in, no loud noises or anything, its just no response from the tranny until about 3k rpm. So i checked the cable linkage underneath (automatic) and thats fine, The cable from the throttle body is connected as well, this all happened after the other day i tightened my throttle cable, but i accidently tightened the top one as well so it was ideling very high when in neutral. I'ev tried everything i can think of can anyone help?
Old Oct 16, 2011 | 07:54 AM
g22cd5's Avatar
Supper Moderator
read your codes 1st and see why your TCU and ECU are throwing codes that's where you need to start.
Old Oct 16, 2011 | 02:28 PM
The throttle cable HAS to go slack, at least a little bit. In the DIY section, search for a post by me about setting the BASE idle.
And read the error codes.
swingkid50
May 20, 2012 09:29 PM
LaGirl
Apr 24, 2012 05:29 PM
foxies
Dec 23, 2010 05:31 PM
qdn745
May 20, 2009 12:17 PM
Ronnie101
Jun 21, 2007 09:44 PM
