94 Accord Ex fuel pump no power
Old May 25, 2012 | 02:35 PM
R.Weed93's Avatar
Default 94 Accord Ex fuel pump no power
I have a 94 accord Ex with the problem of the fuel not turning on. the engine turns over but the fuel pump does not kick on. so far i have checked the main relay, the ECM, and changed the fuel pump. check for power at the fuel pump and there is none. Im about to check for continuity in the wires to eliminate that problem. any other suggestions?
Old May 26, 2012 | 09:28 AM
So at the main relay (pin #4) you have power but none at the pump.....yes check for a broken wire
Old May 26, 2012 | 02:42 PM
Keep in mind that when you turn keyswitch to On w/o start, the fuel pump power line will only be hot for 2-3 secs and then go off. This is normal.
Listen for the main fuel relay (MFR) to click when keyswitch turns On and fuel pump to run 2-3 secs and go off.
If you hear MFR clicks, the fuel pump may be faulty, if you confirm power is getting to the pump.
I found that hammering the pump w/ repeated on/off/on/off... would eventually kick the pump on. Replacing pump fixed problem.
Old May 28, 2012 | 08:53 AM
R.Weed93's Avatar
Checked continuity in wires all the way back to the ignition switch, was only sometimes getting power when you jiggled key same with the starter switch fuse so im going to go ahead and replace that it was only 30$ at the autoparts store
Old May 30, 2012 | 04:37 PM
crispin's Avatar
edited cause the spam message was removed.
Old May 30, 2012 | 11:15 PM
R.Weed93's Avatar
awesome got it to run starts right up now, but now my headlights won't turn on lol i checked all the fuses and dash wiring everythings hooked correctly
Old Jun 1, 2012 | 05:58 AM
Light relay and column stalk switch should be checked.
rockhoundrob
Apr 11, 2014 11:41 AM
Westjoe64
Oct 15, 2012 12:11 PM
kissbally78
Jan 18, 2009 07:14 PM
Mozi
Oct 31, 2008 01:11 AM
davidl
Oct 22, 2008 08:33 PM
