94 accord ex shifting stuck.
Old Nov 27, 2011 | 04:48 AM
Jap.Doe's Avatar
Default 94 accord ex shifting stuck.
I have a 94 accord 5spd, and the shifter has become stiff and unable to move even with alot of force. i cant move the stick at all, any ideas?
Old Nov 27, 2011 | 08:27 AM
g22cd5's Avatar
Supper Moderator
check your shift linkage
Old Nov 27, 2011 | 09:03 AM
Jap.Doe's Avatar
i did, i cant figure it out because nothing broke and there in the same spots they'ev been since i installed the tranny. it just wont move at all, what should i be looking for?
Old Nov 27, 2011 | 09:26 AM
Jap.Doe's Avatar
and the only gears i cant shift into are 1st 3rd and 5th. so i cant move up, and when i move down its not smooth.
Old Nov 27, 2011 | 09:28 AM
g22cd5's Avatar
Supper Moderator
look to see if the linkage is kinked. Also look at the shift forks on the trans make sure they are not bent.
Old Nov 27, 2011 | 12:38 PM
Jap.Doe's Avatar
i dont see any kinks, theres a part on the larger shifter fork that turns really tight but its not kinkied.
and the forks arent bent
Old Nov 27, 2011 | 04:02 PM
g22cd5's Avatar
Supper Moderator
Something has to be binding. When you installed the linkage did you make sure to mount it correctly?
Has the trans been acting up at all? Grinding? Popping out of gear or anything before this issue started?
If it's not your linkage them I'm leaning towards something is wrong with the trans you swapped.
bmarshall
Jan 3, 2007 08:54 PM
dan
Nov 21, 2006 04:07 AM
loci
Sep 27, 2006 09:59 PM
specialfx3000
Aug 29, 2006 01:21 AM
reddcode
Jan 15, 2005 06:11 PM
