95 accord fuel problems
Old Jan 5, 2012 | 10:01 PM
belacccc's Avatar
Post 95 accord fuel problems
I just bought a 95.accand i was told that the horn started blowing then shut the car off and pulled the fuse. Now the injectors aren't pulsing right. Any help please anything would help thank you
Old Jan 5, 2012 | 11:23 PM
Talking I Moved You To This Forum
Not in the right forum for starters so I moved you here..
Please post in the correct threads next post..
Attached Thumbnails 95 accord fuel problems-383957_280108525366405_223846910992567_830074_2088305911_n.jpg
Old Jan 6, 2012 | 08:31 AM
How do you know the injectors are pulsing? Did you take a noid light and monitor them? You can feel them click w/ your hand on them when engine is turning over.
Steering column cable reel fault, stuck horn switch, or stuck horn relay will cause horn to stay on. Get a shop manual from Online Manuals links in DIY forum to guide your work.
Does engine turn over?
First step w/ no-start is to isolate whether fuel or ignition is source of problem. An easy way to do this is to spray starter fluid or throttle body cleaner into intake air duct (3-5 secs) and attempt to start. If engine catches briefly, spark is good and fuel delivery is the problem. If no engine start at all, then spark is missing and fuel delivery is likely (not certainly) OK.
Old Jan 7, 2012 | 07:19 PM
belacccc's Avatar
I rolls over and starts not getting fuel
Old Jan 7, 2012 | 08:45 PM
I'm all for pithy responses, but throw us a bone here and provide some details.
You performed the start test and only got engine start w/ starter fluid?
Old Jan 16, 2012 | 09:52 PM
belacccc's Avatar
hey guys sorry for taking so long, ok this is whats going on, injectors arent pulsing right. starterfluid will fire, other than that, nothing. idk if its my fuel pump a relay or a bad filter or a wire grounded somewhere.
Old Jan 17, 2012 | 05:47 AM
When you turn the keyswitch to On, listen carefully for a couple of soft clicks from under the driver's side dash near radio. Simultaneously w/ clicks the fuel pump should come on in the fuel tank and buzz for 2-3 secs. Fuel pump and Check Engine Light should go off at same time.
Also note whether Oil Pressure and Alt light come on w/ keyswitch.
If you don't hear the sounds described, fuel is not being delivered. Possibilities are Main Fuel Relay (source of clicks under dash) or fuel pump (if you hear clicks but no buzz in tank).
It could be something else but the above are most likely.
rockhoundrob
Apr 11, 2014 11:41 AM
Westjoe64
Oct 15, 2012 12:11 PM
woody
Sep 15, 2010 09:20 AM
kissbally78
Jan 18, 2009 07:14 PM
KimberlyC
Apr 16, 2006 11:51 AM
