95 accord temp gauge not working...
ok i found it.. wasn't sure what it was on though.. i didn't know it was called a thermostat housing lol... I got a temp. sender and its still doing the same thing.. i do know that the previous owner put white faced gauge stickers?? on it.. he left the plastic on them though and I was wanting to eventually take the plastic off. i guess i'll just check the back of the gauge (i'm assuming there's probably a plug or some wires ran to it) and make sure everything is connected.
either that or i guess it could be a sensor?
It looks like #10 is the sender for the temperature gauge. It should have 1 wire.
Turn the car on (no need to actually start the engine, but the key should be in "RUN" position). Unplug the wire & touch it to ground while someone watches the gauge.
Watch the gauge begins to climb towards HOT, but don't let it get all the way up. Take the wire off of ground or you can fry the gauge. If that looks OK, then its probably a bad sender. The "proper" test for a bad sender is to put it in a pot of hot water along with a thermometer. Shop manual should have a table of resistance (ohms) against temperature.
If the true engine temperature never actually gets hot, then you probably have a stuck-open thermostat.
If the engine never actually gets hot would the fans turn on?
Well I got the white faced gauges off.. i'm not sure if unplugging the plugs to get the cluster out or moving the gauge needle did it or not, but my temp gauge started working perfectly after I put everything back together...
Thanks for the info. given! I greatly appreciate it!
You're lucky. It's REALLY easy to damage the gauges when putting on those gauge-face stickers.
And if the engine does not actually get hot, then the fans would ONLY turn on with the AC compressor. If you never get stuck in traffic, always moving down the road, it's very likely the fans will almost never run.
pirulino23
Nov 10, 2010 06:18 PM
stevelaker
Jan 15, 2008 05:38 PM
