96 EX - Radiator Replacement Questions
Old Jul 6, 2005 | 02:33 PM
Buckeye's Avatar
Default 96 EX - Radiator Replacement Questions
All,
I have a 96 4-dr EX with 150K and the original radiator. I noticed a few weeks ago that I was seeing some coolant leaking off the radiator and have identified the trouble spots. The first was a small crack by the neck which was fixed with some JB Weld, but I've also been seeing some leaking around the top seam. Now to my questions:
- I can probably continue working to fill the holes with JB Weld to try to seal the radiator up, but at 150K, is it time for a new one anyway (how long do they usually last ?)
- The dealer wants $500 to replace it and flush the system, while Pep Boys will do it for about the same but include a new thermostat and water output gasket. Does this seem overpriced, or is this about the going rate ?
- How difficult (and messy) is this to do yourself ? I change my own oil, do brake pads, etc., but am unsure how challenging this might be to do alone for the first time. Is this one really best left for the professional mechanic ?
Thanks in advance,
Pete
Old Jul 31, 2005 | 04:25 PM
Evlampius's Avatar
Default RE: 96 EX - Radiator Replacement Questions
If you can change your brake pads yourself - then you must be a level smarter than an average dumb american
The Quotes you have gotten are overpriced
I paid only 99$ for my new radiator while Honda Original costs over 300$ and I had no problems installing it myself.
Ask your local AutoPart wholesalers - just open yellow pages and look for places that sell radiators. (import autoparts)
Make sure that you are getting exactly the same model as there are 2 different ones as Automatic transmission set up is different.
Get a Haynes Manual to help you with the job. Take your time and PLEASE dont flush your old antifreeze down the drain (or i will take my smart comment from this post) I Vote for a cleaner environment.
Use only Honda Original Antifreeze, you can replace thermostat with the gasket if you want - but I would just replace the radiator first.
Other than Radiator get Original Honda Thermostat and gasket from dealer don't hesitate.
Good luck
BigRoach
Jun 3, 2013 01:54 PM
Novaknowledgenow
May 30, 2013 08:58 PM
hmr
Mar 28, 2012 10:49 PM
djklacka
Oct 4, 2010 04:48 PM
